Small Block & Big Block Chevy Specific - bbc cooling question
View Full Version : bbc cooling question
DOUBLESTACKS
02-11-2007, 12:33 AM
I have a 1971 402bbc and a edelbrock rpm performer manifold and a long water pump (mechanical) can someone tell me if i have to run the little hose from the pump to the manifold or can i just plug the holes off and what is the hose for?
Thanks
My01SSCamaro
02-11-2007, 02:11 AM
Im not absolutly sure what the hose it is for i believe it is there so when the thermostat is closed it alowes water to recurculate and all the bbc's my friends from street motors to blown drag motors all have it hooked up so i would say yes it needs to be there
mountainmagic
02-11-2007, 09:46 PM
yeah i agree it does let water flow when the thermo is closed, and you do need it .
8a8mfh
02-12-2007, 07:17 AM
I don't use it, I just drilled 3 or four 1/8" holes around the edge of the thermostat for a bypass.
mrdragster1970
02-12-2007, 11:08 AM
We don't use it ether, if you look at most aftermarket pumps they dont have it anyway. A full drag motor usually don't have a therm, at least I've never seen it, and they run fine. If it's a street type car than I would use it, it will help keep everything flowing smoothly.
If you're that worried about it, and don't want to run it, then drill a small hole in the therm, or a restrictor plate, like it was mentioned.
