Stereo & Electronics - Steering Wheel Controls
Amoretti
02-12-2007, 12:39 PM
My T/A came stock with Stereo controls on the steering wheel (obviously). But when I bought it, none of the lights worked. After about 6 months, one side has turned on. What do I need to check/fix to get both sides working?
Thanks.
Duffster
02-12-2007, 04:35 PM
check the FAQ at the top of the board for steering wheel controls.
Duff
Amoretti
02-12-2007, 05:17 PM
The link for replacing steering wheel lights doesn't work. :(
Duffster
02-12-2007, 05:50 PM
http://www.ls1tech.com/forums//showpost.php?p=3141515&postcount=21
leads you to this http://doghouse.2y.net/gtp/steeringcontrols/
which does work...
Amoretti
02-12-2007, 07:24 PM
Not for me. Not authorized to view this page. :shrugs:
WhiteBird00
02-12-2007, 09:24 PM
Must be at your end...it works fine for me.
Splitz
02-12-2007, 10:14 PM
try disabeling your internet protections to see if that's the problem.
wamp42
02-13-2007, 08:21 PM
I have a Formula and never knew they lit up. I would like to do this but it seems like a lot of work and Im not that skilled or patient.
KEE AUDIO
02-13-2007, 08:36 PM
It's not that hard to do and for the record the link worked for me too.
wamp42
02-13-2007, 10:13 PM
I couldnt get them out. What is the trick? If I pull them out, how do I get them connected again. The connector seems too short.
Splitz
02-13-2007, 10:40 PM
it's the tightness that's holds them in, there two clips on the side that keeps them connected.
