Small Block & Big Block Chevy Specific - L98 vs LT1
View Full Version : L98 vs LT1
eLTwerker
03-04-2007, 06:40 PM
I'm sure this has been done a million times, but can anyone give me a link comparing and contrasting L98s to LT1s? I love 3rd gens but would like to start learning the ins and outs of the L98 engine. Didn't it come in Corvettes of this era too?
Also, what cars came with L92s? How are they different from L98s?
Formula350sd
03-06-2007, 12:00 AM
L92 is a throttle body motor if I recall correctly
differences between L98 and LT1 lets see what I can come up with off the top of my head
L98 gen 1 small block LT1 gen 2
L98 21 inch runner LT1 3 inch runner
L98 standard cooling system LT1 reverse
L98 uses standard dizzy LT1 has cam driven dizzy behind water pump
L98 in F body uses iron heads only Vette gets aluminum LT1 in Vette and F body is aluminum B body LT1 is Iron head
Cams are totally different
L98 belt driven water pump LT1 cam driven
I think thats about everything if you have any other questions let me know
FieroZ34
03-06-2007, 12:24 AM
To sum it up:
LS1 > LT1 > L98
If it's newer, it's better.
http://img.photobucket.com/albums/v336/AaronZ34/Motivation/tpi8cn.jpg
nomorews6
03-06-2007, 12:45 AM
the one thing i remember about my old IROC is that on the street it was a monster. It only ran a low 13 to high 12 but the low end torque was rediculous! It would fall flat on its face after about 5200 rpm though :)
Randy_S
03-06-2007, 01:09 AM
Another difference, the L98 uses a distributor and the LT1 uses the OptiSpark.
eLTwerker
03-06-2007, 11:49 AM
Two questions...what's the runner and what is the dizzy?
Firebat
03-06-2007, 12:06 PM
I like the 94+ LT1 because they use a flash chip in their computer that can be program or read by a laptop. Don't have to burn chips or anything like that. The 94+ LT1 computer can just be reprogrammed for the speedometer for gear or tire size changes, no need to change out speedometer drive/driven gears.
You don't have to have a thirdgen with the engine that came with it(L98, or whatever). You can swap in a LTx/LSx. I've even seen a few thirdgens for sale with a LT1 already installed at thirdgen.org in the past year.
NemeSS
03-06-2007, 12:50 PM
runner is the tube on the plenum,
dizzy is the gear that replaces the dist. on lt1's.
still drives the oil pump.
eLTwerker
03-06-2007, 01:45 PM
the oil pump is in the back of the block, water pump is in the front on LT1s. How can the dizzy drive the oil pump in LT1s? The oil pump is driven by a gear driven shaft perpendicular to the cam(also driven off the cam).
Quick1998Z28
03-06-2007, 01:51 PM
the L98 is no different from any 350 you get out there. 9.5:1 comp, all iron, stock bottom end is good for 6500 rpm and ~550 HP n/a
Everyone centers around the stupid factory intake as if you can't take it off, sell it to some street rodder on ebay for a good chunk of money, and replace the turd with an Holley Stealth Ram and have no RPM cap whatsoever (lest you spin past 8000 rpm)
FieroZ34
03-06-2007, 02:59 PM
So is it 6500rpm or 8,000rpm?
And those heads must be quite godly to support 550hp.
Same with the cam.
And that distributor.
And that holy EFI system.
So basically, replace every part related to it being an L98, and it can perform like any other SBC. Who coulda guessed? You're genius.
Strokinit383
03-06-2007, 05:42 PM
The LT1 has more power in stock form than the L98, but i think the tpi has much more potential and can be had for much less. Since stock sbc parts will work, you have a vast array of parts to use. With upgraded pcm and runners, it performs very well, plus no opti to deal with. The longer runners on the tpi also make for a much more torque producing street motor.
Formula350sd
03-06-2007, 10:57 PM
Anybody that says you cant make good power with a TPI and Long runners is a fool
http://www.thirdgen.org/techboard/tpi/410837-400-rwhp-tpi-dyno.html
and I know for a fact that TPI gets along well with turbos and can go fast with very little
FieroZ34
03-06-2007, 11:03 PM
400whp isn't that good though. An LS1 can do that with bolt ons.
91Z28
03-07-2007, 07:35 AM
You mean bolt ons and a cam.
Genesis_26317
03-07-2007, 09:07 AM
I feel so sad whenever I see my father-in-law drooling over a TPI like it is the most powerful engine on the road.
If you want to go old school go big block. Not many people can say that a SBC (or a factory TPI) is better than a BBC.
the_merv
03-07-2007, 11:54 AM
Those Engines are good till about 5000 RPM's.. A friend of mine has one. He shifts at 4800, I am still building power in my LT1 at that RPM.
Formula350sd
03-07-2007, 12:13 PM
Thats a really mild motor and people always forget to mention that an LS1 has a 15 DEGREE cylinder head and the advantages of years of research in runner design that came after the TPI engine (I know newer is better) if you need more than 400 wheel horse in a street car to cruiz around in you got a problem race cars are a different story
the_merv
03-07-2007, 01:00 PM
..if you need more than 400 wheel horse in a street car to cruiz around in you got a problem..
I don't need that much, I want that much..That is why I am building a 408ci L92.
There is nothing wrong with having power on the street, just don't hammer it all the time. When someone wants to play, then bring it out and fuck them up.. :judge:
FieroZ34
03-07-2007, 01:29 PM
You're happy with 400whp?
Do us a favor, buy a Honda.
Formula350sd
03-07-2007, 01:45 PM
As a driver that would be nice I wouldn't build a long runner car as a race machine just a nice stoplight racer a street cruiser or maybe auto X car
OH and FUCK YOU I'll buy whatever I please thanks
Not everything has to be built heavy and not everybody wants 500+ Wheel horse sometimes a large area under the curve is more desirable
Strokinit383
03-07-2007, 01:51 PM
I personally think this post, along with every other one of yours in this thread, is rediculous. There was nothing in the original post about ls1's. The ls1 is a superior motor in every way to both the lt and tuned port but that wasnt the question. 400 wheel horsepower is a lot of power and very fun to drive on the street. From the sound of things you dont have anywhere near this. A stock ls1 will put down around 300 at the wheels. 400 wheel hp will equate to roughly 460 flywheel hp with 15% drivetrain loss. No bolt on only ls1 can do that, you will have to add a cam or mild FI to get to that number. The L98 has much potential with newer technology and can be built cheaper. 5000 rpm shift points are fun on the street when you dont need or have the room to rev past 6500. Why place extra stress on your motor from the extra revs when you can make that power lower in the powerband? If high revving is what its all about, then why do people even bother to build 383's???? Why not just build 327's and rev them to the moon? Because they want low end grunt and street-friendly torque. Please take your useless comments and informationless posts elsewhere as this is a friendly forum dedicated to answering questions and helping others solve their problems. So go have fun at your fiero forums or driving your mommy and daddy's Camaro and come back when you buy your own.
Formula350sd
True but there gets to be a point where drivability is compromised for huge power on the street a power adder is where its at IMHO
Do I need half the shit I have on my car fuck no do I want it yes
Point is theres a car and a motor for everyone and everyones application just because its not up to your standards doesn't make it any less cool if you want a huge high horse motor go for it but don't belittle other peoples shit just cause your shit makes more power thats just an asshole thing to do
Formula350sd
03-07-2007, 01:52 PM
Thank you thats the best post in this thread yet IMHO
Quick1998Z28
03-07-2007, 02:13 PM
Same with the cam.
Are you fucking retarded? Did you fail reading comprehension? The BOTTOM END can handle 550 HP and 6500 rpm. An HSR can provide airflow in a 350 for up to 8000 RPM. The heads aren't that great, so you REPLACE THEM with good ones. Kinda like when you take an LS1, put a cam, and heads on them, you know to make them go FASTER. Asswipe... :eyes:
Quick1998Z28
03-07-2007, 02:32 PM
just curious, but how much does your turd SS make? I am sure my LS1 makes more. Besides with a name like FieroZ34, your opinion and taste in cars is completely illegitimate.
the_merv
03-07-2007, 07:00 PM
How about we all stop being bitches and get back to the Thread Topic..
L98, or Tuned Port..
Basically the same low-end as the LT1, still a Gen I 350, just without the Reverse Cooling. It has the standard Distributor, and the Water Pump isn't driven off of the Timing Chain. The upper end is the power killer, long runners give it good torque at low RPM, but it's maxed at like 5K. I have seen an after market setup that had 4 Runners, instead of 8.
The LT1..
Similar low-end as the L98, but Reverse Cooled and with the suttle differences as metioned above. It also uses the OPTI Spark Distributor. The upper end however, little bit better setup. Heads are capable for higher Compression cause of the Reverse Cooling, they flow a little better, and the Intake has them nice short 9" Runners, capable of going to some good high RPM's.
Both are Multi-Port Fuel Injected, and use the same Throttle Body.
I am sure someone can fill in the rest..
The stunningman
03-07-2007, 08:07 PM
A LT1 is nothing more than a reverse cooled L98 with Vortec type heads and a good MPFI.
Its everything SBC guys have hoped for.... with some really big QUIRKS. 1) the cam driven water pump, 2)the POS opti, and 3)the plastic oil pump drive necessated by the POS opti. Other than that the LT1 is golden.
There are solutions to all the quirks as usual.
slick1851
03-07-2007, 08:50 PM
Um 400hp AT THE WHEELS! Is good enough on the street.....
Fuck how fast are bolton LS1s going with a tire? Yeah 11s!
And thats in the mid 300hps....
Formula350sd
03-08-2007, 02:33 AM
I hope your including the head in those numbers cause an LT1 intakes runner is way shorter than that
the_merv
03-08-2007, 08:10 AM
Total length of the Runners, including Heads, is like 9". The L98 is around 27". Good Torque, but hits it's limit quick. The LT1 Intake can out-run the Engine.
mzoomora
03-08-2007, 09:42 AM
You could also do a TPIs mini ram for a L98. Very similar to a LT1 intake and shows great gains up top compared to the stock intakes.
Formula350sd
03-08-2007, 01:07 PM
or an lt-1 intake conversion but I think Holley stealthram is the best option it gives a very wide power band and IIRC its fairly similar in length to LS1 intakes
