xdamxincx
03-06-2007, 01:11 AM
i am upgrading to a bigger carb so i need to sell this one .
this carb is barely used probaly 10 passes at the most
no shaft play . like new condition
it is a custom built pro systems racing carburetor.
here is the specs
dominator bowls and metering blocks
1000 cfm
HP main body
Adjustable air bleeds
Billet Base Plate
Balanced drag float (12.5 grams)
Screw-in jet extensions
Clear sight plugs
Stainless plate screws
Custom sized needle and seats
Electronically wet-flow calibrated
Custom "true race" curve
Live-engine tested
Techline access
Wet-flow dyno sheet for easy jet selection $600.00 shipped.
my email is xdamxincx@aol.com
http://img.photobucket.com/albums/v686/xdamxincx/carb.jpg
http://img.photobucket.com/albums/v686/xdamxincx/carbsheet.jpg
here is the specs
1000 cfm
HP main body
Billet Base Plate
Clear sight plugs
Live-engine tested
Techline access
