Small Block & Big Block Chevy Specific - 383 HP est. please
View Full Version : 383 HP est. please
streetassasin
03-12-2007, 02:00 PM
I am in the process of building a 383 stroker. My plans are 906 vortecs with a bowl blend and stainless valves, either a lunati bracket master II cam 292* adv duration .480 lift or a lunati streetmaster cam with 285* adv. duration and .507 lift, lunati springs and lifters, stock rockers, cast rotating assembly, with hypereutectic pistons approx. 10-1 comp, edelbrock performer rpm, 750 holley dbl. pumper, mallory HEI dist and a hyfire VI-A ignition box, all through hedman 1 5/8 long tubes with duals and 3'' dyno max bullets. Is 400fwhp too optimistic?
jmm98LS1
03-12-2007, 02:19 PM
I think 400fwhp should be pretty easy. I'm currently building a very similar 383......10.4:1 comp, 906 vortecs w/beehive springs, hyd roller 230/236 cam (.544/.555 lift), rpm air gap intake, 750 carb, 1 5/8 longtubes. I'm shooting for 450ish fwhp and 475ish fwtq......I think I'll get fairly close based on dyno sheets I've seen from similar combos.
NemeSS
03-12-2007, 02:49 PM
pm sent
streetassasin
03-12-2007, 03:01 PM
damn dude lol thats some power. More info on the cam please its basicly the same motor beside the cam
streetassasin
03-12-2007, 03:02 PM
pm sent
Your 3 days too late lol
jmm98LS1
03-12-2007, 03:28 PM
pm sent!
streetassasin
03-12-2007, 03:38 PM
pm sent!
What rpm do you plan on running it to?
jmm98LS1
03-12-2007, 04:15 PM
Planning on shifting at 6000rpm.
streetassasin
03-14-2007, 11:27 AM
I am also considering a comp xe284 with comp double valve springs. Which would be the best cam to try to break in to the 12's all motor
FU_I_AM_UltraZ
03-15-2007, 09:28 AM
if you can afford it, i'd step up and do a 406 smallblock.
joewee350
03-15-2007, 09:42 AM
What is this engine going in? Breaking into the 12s isnt that hard especially with the parts list you put up. My s10 ran a 12.7 on street tires BEFORE the cam and stall in my sig. It is a whole new animal now. Shooting for 11.9 with a tire. You should reach your goal no problem.
streetassasin
03-15-2007, 10:29 AM
I can get a assembled 383 or 389 short block for $800 so thats what I am going with. Its going into the thirg gen in my my sig.
FU_I_AM_UltraZ
03-16-2007, 09:53 AM
for $800... doesn't sound like i'd last long. not with my top end combo at least lol
streetassasin
03-16-2007, 10:15 AM
One of my dads friend own a machine shop and can get the rotating assembly at cost for $700 and will sell me a 350 4bolt block for $100
SERIALPIMP
03-16-2007, 01:59 PM
It should make abotu 380-400 hp,
but no more than that with those heads.
LAter if you upgraded to some larger heads and a Victor Jr,, you could see 470 - 480hp. Maybe some DART Iron Eagles, they are good head for the money.
That Lunait Bracket Master II is a great CAm, I had one in my car in High school!!!
loved it,
badasschevy123
03-20-2007, 08:17 PM
i just put a down payment on a 383 stroker with cast crank and forged pitons and h rods. im runnin a edelbrock air gap, holley 750dp, msd 6al, 2800 stall, afr eleminator heads, what cam should i get? its a daily driver but occasionaly going to spray 200 shot. :drive:
CNC BLOCKS N/E
03-20-2007, 09:59 PM
Check this link out as this engine with AFR's we built made 501 on the torque and 455 horse and the same engine with a well prepared set of Vortecs 906 casting made 496 on the torque and 449 horse. And both are daily drivers in the summer.
http://www.chevelles.com/forums/showthread.php?t=106715&highlight=DYNO
JohnFrazee02SS
03-20-2007, 10:13 PM
i just picked up a 1988 300ZX for 1200 my plan is putting a 383 stroker in and a TH400 with about 3k stall and a 10 bolt from a 98 Z-28. should be fun until i break the rearend.
FU_I_AM_UltraZ
03-23-2007, 10:47 AM
i'd go with a solid cam and something close to a 300 degree duration and around a .550 lift for int. and ex. that and LTs you'll make about 480 to the wheels w/o NOS. you'll just have to keep up with adjusting the valves daily. or if you want a close to maintainance free motor... get a regualr cam with pushing a .600 lift and about a 230 duration.
streetassasin
03-24-2007, 07:28 PM
I decieded that I dont have time to build a motor so I am selling the car to buy a lt1 4th gen
JohnFrazee02SS
03-25-2007, 10:17 AM
yeah you'll be seeing my tailights
streetassasin
03-25-2007, 08:19 PM
yea man you will destroy it :eyes: even though I have a guy extremely intrested in buying it for 5k and I fould some nice lt1 cars for around 4k. So right after I get the lt1 I will prolly dump around 2 grand on boltons nitrous and tires. I think it should be a solid 12 sec car and thats all I was after with the vortec motor.
later dude :moon:
