Stereo & Electronics - Subs hook up on Stock radio
View Full Version : Subs hook up on Stock radio
Z28kid86
03-12-2007, 09:16 PM
Does anybody know if you can hook up subs to a stock cd player???
95bat
03-12-2007, 09:23 PM
Just stick the wires straight into the volume knob and they should play perfect.
KEE AUDIO
03-12-2007, 09:27 PM
Direct quote from the Monsoon FAQ/ Upgrading the Monsoon at the top of the stereo and electronics page:
Adding a sub to the factory system is relatively easy. The most common method is to add an amp and mount a stealth box with a 10" sub in the cubby space on the left of the t-top storage area. You will need a line-level adapter that is available for just a few bucks from any stereo or electronics shop. It will convert the speaker-level output of the head unit to the pre-amp (line-level) input needed by most amps (you can also buy some amps with speaker-level inputs). A common place to mount the amp out of sight is with a mounting board at the back of the car below the hatch lock. There are all kinds of options if you want to show off your amp - check out sites such as subthump.com for some ideas.
No offense but please try looking around a bit as there is very useful info in the FAQ's!!!
