chuy10
03-14-2007, 02:23 AM
I was wondering if someone can tell me what the diference is from a 4volt and a2.2 volt on rca outputs both are mp3 player thanks
dragonrage
03-14-2007, 03:46 AM
The difference is how much gain you need to apply with an amplifier to get an equal amount of power out. Other than a potential yet inaudible difference in signal to noise ratio (SNR), just the gain setting. Both voltages are in the range that basically any amp will work optimally.
fredmr39
03-14-2007, 04:06 AM
So if that wasn't clear, higher pre-out V = better, but as mentioned, both will do the job for a single amp (if you plan on running multiple amps off of one pre-out for some reason, get the higher voltage pre-outs).
