Stereo & Electronics - Sail pannel speakers inop...
RUDE SS
04-11-2007, 01:44 PM
So on my camaro I have the factory monsoon system but recently the sail pannel speakers like the "subs" I would say quit working on me.What could it be? Amp? Just before they stoped working I could hear 1 speaker going out. Could that be the reason why they both stoped working?
KEE AUDIO
04-11-2007, 03:33 PM
Your the 2nd guy this week this has happened to..lol!! http://www.ls1tech.com/forums/showthread.php?t=692865&highlight=sail+panel+speakers
Get some new midbass and call it a day. They'll sound better than the stock ones did anyway!!
shouldaboughttheZ
04-11-2007, 03:36 PM
as stated above, they have crapped out.
RUDE SS
04-11-2007, 04:07 PM
Thats what I thought.Thanxs for the help guys :)
RUDE SS
04-11-2007, 04:42 PM
IF 1 goes out would it make both not work?
shouldaboughttheZ
04-11-2007, 05:16 PM
no. The other one would still work.
RUDE SS
04-11-2007, 05:54 PM
I had both go out at the same time so would it be a amp problem then?
ls14thefun
04-11-2007, 08:40 PM
when one of the speakers went bad it could have gounded out casing that whole channel on the amp go bad. the only way to know for sure is to take the speakers out. take a 9volt battery and go from + on the battery to + on the speaker and the same with both -'s. if the speaker moves then it is the amp. you could also use a meter and put it on ohms and check the ohm load of the speak on the + and -. i believe they are 8ohm speakers so if the meter tells you anything other than 7.6 to 8.3 or so ohms the speaker is bad.
RUDE SS
04-12-2007, 02:51 PM
K thanks ill give it a try
