Stereo & Electronics - My car alarm
View Full Version : My car alarm
bmxer8699
05-14-2007, 11:43 PM
my car came with this audiovox remote start. and recently its been going off for no reason at all around the same time at night. no one is touching it, ive checked the camera i have set up, it just randomly goes off for no reason, and i dont have any manuel with the alarm..
any suggestions?
if i posted this twice my bad, the sites messing up
WhiteBird00
05-15-2007, 10:10 AM
Is the remote starter also an alarm system or is it the factory alarm going off? The factory shock sensor is known for going bad and causing exactly the symptoms you describe. You can try turning down the sensitivity but often replacing or at least disconnecting the sensor is necessary.
bmxer8699
05-15-2007, 04:01 PM
not sure, theres a sensor in the trunk though by the spare tire that looks god awfully old, never paid attention to it.
WhiteBird00
05-15-2007, 04:15 PM
not sure, theres a sensor in the trunk though by the spare tire that looks god awfully old, never paid attention to it.That's the factory alarm shock sensor. A good way to tell if it's the factory alarm or an aftermarket one that is going off is whether it is a siren or the stock horns sounding. The factory alarm uses the horns but almost all aftermarket alarms have their own sirens. If the horns are blowing then try disconnecting the factory shock sensor and see if the false alarms stop.
bmxer8699
05-24-2007, 12:35 PM
i dont see a seperate horn under the hood though.
WhiteBird00
05-24-2007, 01:50 PM
i dont see a seperate horn under the hood though.Well, if it was installed by a good intaller than that's the way it should be. My alarm has the siren horn hidden under the battery so that it can't be easily disconnected by a would-be thief. The sound will be different for an aftermarket alarm. If it sounds just like the factory horns blowing then chances are it's the factory alarm. If it sounds like a siren or has varying tones then it's an aftermarket alarm.
bmxer8699
05-24-2007, 05:44 PM
hmm, ill look after the rain clears up and get back with you
