Stereo & Electronics - Antena Question (fixed to power)
View Full Version : Antena Question (fixed to power)
subtlez28
05-15-2007, 12:50 AM
Just wondering...
I have a fixed antena. Is the wiring there to swap in a power antena? What is involved/needed 4 the swap?
I'm sure this has been covered but the search isn't working 4 me.
Thanks
shouldaboughttheZ
05-15-2007, 09:29 AM
For a camaro, the wiring is not there. You are going to have to run a remote on wire, can do that from the headunit by adding the wire to the harness. Splice into the power wire from the monsoon amp and ground it somewhere in the back. It is not to difficult, as I have done this.
subtlez28
05-15-2007, 09:37 AM
Thanks 4 the response.
But, Bummer, not what I was hoping 2 hear. The only reason I want it is because when I back into my 2nd garage, I back the rear under a loft. I have 2 pull the antena off, It woulld b easier to have a power antena, but taking it off is only a minor inconvenience.
dragonrage
05-15-2007, 12:01 PM
Adding the wire is a pretty minor inconvenience as well.
VIP1
05-15-2007, 12:12 PM
http://www.blackcamaro.com/antenna.htm
smg267
05-15-2007, 08:27 PM
you beat me too it. I had that site book marked for like a year! :)
VIP1
05-15-2007, 10:28 PM
I really do have you beat.... I went to school with the guy. :P :)
I've known about the site since it went up 6yrs ago. :burn:
:alien:
subtlez28
05-15-2007, 11:26 PM
Thanks 4 the info guys.
I'll probly do this a little later... My headers have been in boxes 4 a year... I have more ideas than time. I was hoping that since I have the Monsoon, it would already have the wires.
That said, it seems pretty easy to wire it up.
Mike02Z
05-16-2007, 08:25 AM
The wiring is the easy part. Gettting the antenna to mount is the difficult part. The firebird antenna does not mount to the same point as the Camaro antenna. You need to drill a new hole and that metal is thick. I did this myself last year. I love the way it turned out but it was not as easy as I expected.
subtlez28
05-16-2007, 12:05 PM
Really? I was already 2nd guessing this due to the hole I have 2 drill in the bottom 4 the vent.
U have 2 drill an additional hole in the quarter panel (or just enlarge the existing one)?
