Stereo & Electronics - steering wheel buttons stop working
hnaskoct
05-15-2007, 05:38 PM
what could cause the buttons to stop working and lighting up but its still plugged in at the botom. do they go bad?? help plz
JustinID
05-15-2007, 06:31 PM
Blown fuse?
gi8e7oi825
05-15-2007, 06:50 PM
Is your airbag light on too? This was my problem: http://ls1tech.com/forums/showthread.php?t=602011
hnaskoct
05-15-2007, 07:02 PM
Is your airbag light on too? This was my problem: http://ls1tech.com/forums/showthread.php?t=602011 the fuses are ok and the airbag light is on
WhiteBird00
05-16-2007, 08:08 AM
the fuses are ok and the airbag light is onDid you test the 1-amp steering wheel control fuse? Or did you just visually inspect it? I can't tell you how many times we've had somebody say the fuse was okay after looking at it but it was really blown. Always either test or replace with a known good fuse.
The switches almost never wear out (at least not all at once) so the fuse is the most likely culprit. If not then it could be a connection someplace or the contact ring in the steering column. Does your horn still work (it uses the same contact ring)?
