Small Block & Big Block Chevy Specific - 5.0 Chevy pulley explodes
Captainofiron
05-22-2007, 12:54 PM
yea read the title
http://i47.photobucket.com/albums/f178/IamStonePhillipsthe1/P1040379.jpg
http://i47.photobucket.com/albums/f178/IamStonePhillipsthe1/P1040377.jpg
ever see that happen?
383LT1S10
05-22-2007, 02:19 PM
Not on anything short of a 8,000rpm race engine lol. Must have had a fatigue point such as a gas pocket in the metal. Pull it off and take a look at the failure points. Bet you will find the point at which it failed. Thats crazy.
redbandit98
05-22-2007, 03:12 PM
did the bearing lock up or have enough slop in it to let it get wallered out and then let go? Ive had to replace a few of those bearings on the serpentine setup on the idler pulleys like that one.
Captainofiron
05-23-2007, 08:01 PM
I also had a feeling it was a residual stress crack from the manufacturer its the only thing that makes sense.
when I looked at the crack you can see where it started, so I think it just finally hit the fatigue or endurance limit and gave way to the tension of the belt
there is nothing around that it could have hit, the bearing was perfect, I had barely had that thing on there for 2 months
that is the first time I have seen a smooth metal pulley do that
