Small Block & Big Block Chevy Specific - 305 head and valve issue???
View Full Version : 305 head and valve issue???
FU_I_AM_UltraZ
06-14-2007, 04:46 PM
I've got a 305 that i'm planing on using while is save and rebuild my stroker motor. I have brodix T1 heads with 2.08 and 1.60 valves...
Can I use them on a lil 305 w/o damaging the valves? the cyclinders look smaller than the int. and ex. valves put together.
Any help would be great!!!
Thanks
-Charlie
ulakovic22
06-14-2007, 05:12 PM
I don't think those will work. The largest size I have heard of fitting are 1.94/1.5, the bore is only 3.7xxx I think.
Demon_Speeding
06-14-2007, 05:58 PM
Nope, unfortunately the 305's bore is too small to run anything larger than the 1.94/1.5. The 305 has a 3.74" bore and 3.48" stroke. Besides that, those heads would likely cost you power due to the fact that even if the valves would fit, the tight bore would shroud them hurting flow.
FU_I_AM_UltraZ
06-19-2007, 12:45 PM
okay thanks guys. I'm going to look for a cheap 350 then for the meantime...
