Small Block & Big Block Chevy Specific - Procharghed zz1, how much boost?
capn smokey
06-22-2007, 11:12 AM
I am going to be putting a p600b procharger kit on my zz1 and i was wondering what a safe boost level would be. It is 8.8:1 compression and already has a mls hg and head studs, my mods are in my sig.
jmm98LS1
06-22-2007, 11:27 AM
Are you running hyper or forged pistons?
whiteghost
06-22-2007, 05:00 PM
I'd say 10lbs if you want to err on the safe side. I've been running 8lbs on my gm350ho crate engine w/ 9.1:1 compression. Timing reduction will be critical to avoiding detonation. I'm using a msd boost timing master that pulls out around 1.3 degrees per pound of boost. The btm is adjustable, it can pull from .1 to 3 degrees per pound of boost it sees and also lets you adjust the initial reduction as soon as it sees any boost (0,2,4lbs if i recall). Keep your afr's nice and fat and get a good carb hat (low profile procharger hat sucks) Extreme velocity makes a nice hat but its pretty pricey to boot. Good luck.
Oh, and if you plan on running a front mount intercooler or methanol injection I'd say you can go as high as 14lbs.
capn smokey
06-23-2007, 02:40 PM
thanks, its a stock zz1 short block. forged crank, powdered rods, hypereutectic pistons.
whytryz28
06-24-2007, 02:38 AM
6-8 lbs with hyper"craptic" pistons. Speed Pro makes cheap blower pistons that a dished and forged, think about swapping them out if your serious about making alot of boost.
