Small Block & Big Block Chevy Specific - lets talk heads
View Full Version : lets talk heads
BigBlock10
06-29-2007, 04:34 PM
well guys i am in the market for new heads :drive: the motor i will be puting them on is a sbc 355 with a procharger d-s1. the motor will not be taken past 6500 RPM. now the problem is what brand to go with, there is about a million diff brands out there. AFR, world, brodix, DART. thats just to name a few, what would you guys go with? for alum heads in the $1300 range
thanks for the time guys
DEREK
blown454ss
06-29-2007, 05:25 PM
trickflow
merriman44
06-29-2007, 07:30 PM
AFR's new eliminator series seems to be a good head. If I was you I'd hit them up and see what they can do for you. I'm going to use their 180cc head.
Ryan02SS
06-29-2007, 10:13 PM
AFR Eliminator's all the way.
Villain281H
06-30-2007, 02:02 PM
Canfield makes nice aluminum SBC heads as well, I have a set on my Nova's 383 powerplant.
Derek
1997bird
06-30-2007, 03:11 PM
Dart's new platinum series aluminum heads are a great lower cost cylinder head that utilizes wet flow technology. http://www.chevyhiperformance.com/tech/engines_drivetrain/cams_heads_valvetrain/0705ch_dart_cylinder_heads/index.html
vanilla89
06-30-2007, 03:38 PM
Pro Top Line 235's or Dart Pro1 230's are the best untill you go offset rockers or 18*...IMO
Dont get cought up in all the "AFR" hipe,IMO it's over priced junk
capn smokey
06-30-2007, 04:26 PM
AFRs eliminators are awesome heads but the trick flows can make some sick power too, I would check out some super chevy and hot rod write-ups on them.
1997bird
06-30-2007, 04:40 PM
AFR makes quality cylinder heads! They do cost more than most heads and have a lengthy delivery time (usually if you order directly from AFR). Those are about the only down falls that I have seen with them.
BigBlock10
07-02-2007, 12:03 PM
cool, thank's for all the info guys
AutoRoc
07-03-2007, 03:54 PM
Is this a street motor? Even with low RPM, will there be a lot of boost? Is it cammed for 6500 max or does it have stock rods/valvetrain? Auto with high stall or manual trans? if AFR195 Eliminators were avaliable I'd try them, assuming they don't cost more than their old stuff.(less than $1500). AFR210's or a Dart 215cc might be nice too. All depends on if you are looking to wring out a lot of power or just want something torquey...Can you get cam specs?
ulakovic22
07-03-2007, 04:34 PM
$1300 each or for the pair? I'm going with a set of RHS heads on my BBC project.
