Small Block & Big Block Chevy Specific - how big for the street?
ProStreet_632
06-30-2007, 02:28 PM
Hey guys, anybody running big cubes on the streets these days, just seeing what is out there...
I have a 632 in the works
Donavon Aluminum block
Callies 4.75 crankshaft
eagle 6.7 rods
Je Custom 10.5 compression pistons(pump gas motor)
Brodix Big Brodie heads(done by Reher/Morrison)
Dart intake
Comp solid roller(it's big) thats all I can tell you.
backed by a Turbo 400 with a brake
Should get about 5-7 mpg, not a economy car thats for sure
capn smokey
06-30-2007, 04:27 PM
What did that donovan run you $$$$?
ProStreet_632
06-30-2007, 05:16 PM
$2000 used, came with 2 new sleeves that I had to install
ulakovic22
06-30-2007, 11:07 PM
That's definitely big. I'm going to be running a 555 in my T/A.
G&HRacing
07-01-2007, 12:59 PM
540 going to 565 next rebuild. Rarely street driven these days, no more than a few laps around the block the last few years, just so it's considered "street driven". Engine size has nothing to do with streetability anyway, it's camshaft size and how long will the lifters and springs last.
stainless40cal
07-04-2007, 02:22 AM
WOW bro let me know if you see another aluminum block for that price used ill grab it asap
78novacaine
07-04-2007, 07:47 PM
holy hell, that sounds like a badass setup :thumb:
p.s., what color is your 67, just wondering if i have seen it around town
JUICED96Z
07-04-2007, 09:36 PM
Sounds sick, I you sure you don't mean 5-7 gallons to the mile??? :D
As long as you have a good top notch aftermarket cooling system you should be ok. My 468 stays cool all day long with two sets of fans and a belt driven water pump. One of the fans is attached the the water pump (ditching that soon for an electric water pump).
As stated above more of the issue is cam size and valvetrain
383lt1impala
07-04-2007, 10:34 PM
Well You Can Go As Big As You Want Aslong As It Lasts
ProStreet_632
07-05-2007, 11:35 PM
I got lucky on the block, most likely will not c another like that, unless it has been destroyed.
ProStreet_632
07-05-2007, 11:37 PM
It will be stay cool, already have the radiator and fans to go with it, no problem on that...been dealing with big blocks for 20 years know, never hade 1 overheat. As for the valve train, it will be fine, just have to adjust them every now and then
JUICED96Z
07-06-2007, 04:14 AM
HMMM I have allways been told the larger CUI you go the harder it is to keep cool. IE 5XX and up.
slick1851
07-06-2007, 02:09 PM
Wouldnt that depend on the car? And what your doing with that motor?
JUICED96Z
07-06-2007, 02:17 PM
Yes, but I doubt someone building a 6XX motor is building something mild :D
ProStreet_632
07-06-2007, 02:21 PM
Just went from a 598 in a street car for 3 years with no problems, to a 615 in a buddy of mines car....depends on how its built and who built it, it will be fine
JUICED96Z
07-06-2007, 02:34 PM
Im sure it will be fine, was just curious :)
ProStreet_632
07-06-2007, 02:53 PM
It will be kinda mild, most people don't know that more cubes, eat up the agressiveness of a pretty good size cam and calms it down some.
93Polo
07-06-2007, 02:55 PM
Sounds like a carzy 1st gen :drive:
I do know of one other 632" streetcar a 67 Vette. He posts on Corvette and sometimes Team Chevelle.
http://forums.corvetteforum.com/showthread.php?t=1728758
JUICED96Z
07-06-2007, 03:04 PM
Thats true, the more CUI the smaller the cam is in the motor. As in a BIG cam gets smaller with the more CUI the engine gets.
For a 350 a .650 lift cam might be considerd big but for like a 408 its just right.
Its all relative.
ClemsonT/A
07-06-2007, 04:03 PM
I am planning a 572 crate with a cam swap for my 1969 Impala backed by a th350. looking for around 600 rwhp in the street car. It was my first car and a gift from my great grandmother.. I am rebuilding the car in her memory. She bought it brand new in 1969 (paid cash) 327/pwerglide 2 door vinyl hardtop. :)
stainless40cal
07-08-2007, 02:32 AM
Hey to the op let me know what kind of numbers you put down as i am doing a very similar set up in my 70 nova this winter im interested i would really like to break the 1000hp mark on 93 octane with no power adder but im having trouble finding people who have done it......
ProStreet_632
07-08-2007, 08:35 PM
It will be tough for 1000hp, on pump gas. We just dynoed my buddies 615 and it made 853hp with 1 carb. The 632 should be around 860-870hp or so on 1 carb, but that is plenty to drive around with, anymore I would need to raise the compression and change the heads, and I just don't want to do that...remember street car on pump gas....
G&HRacing
07-09-2007, 03:22 PM
It will be kinda mild, most people don't know that more cubes, eat up the agressiveness of a pretty good size cam and calms it down some.Just as hard on the springs and lifters though. Just curious, what kind of lift are you going to run?
I'd like to do some more street driving, but right now I have .748 lift camshaft, I just don't know how long springs and lifters will last and I like racing a lot more than working on it. I'm thinking about when I rebuild it to go to a bigger diameter camshaft with roller bearing and bigger diameter lifters. Maybe even titanium valves to take some weight out of the valve train. It seems valve springs keep getting better, just not sure what brand to use anymore. I've used K-motion for years, I know there's a lot better out there these days. I've never really talked to anyone that has drove big camshafts on the street for very long.
62ls1
07-09-2007, 04:13 PM
Hey as far as cubic inches go on the street .... here's my brother in laws STREET DRIVEN Chevelle which is for sale..... ebay item number 200127285983
565 pump gas BBC ...
