Small Block & Big Block Chevy Specific - carb 350 hesitation
View Full Version : carb 350 hesitation
t6378tp
07-05-2007, 01:18 PM
I have a 91 s10 with a carb'd 350, the problem is the when I floor it from idle or low rpms it hesitates before it takes off
now I have replaced the plugs, checked for leaks around the carb and will check the timing and for vac leaks today if these things all check out fine it there anything else it could be
1997bird
07-05-2007, 01:59 PM
What type of carb is it?
t6378tp
07-05-2007, 02:02 PM
650 holley street avenger with vac advance
1997bird
07-05-2007, 03:27 PM
Check what your intake vaccum is at idle and then divide that by 2. This number will give you the correct power valve to use, the factory power valve is a 6.5. If that checks out, then I would start playing with the accelerator pump stroke to see if it needs more fuel or less fuel for the hesitation to go away. You may need to change the accelerator pump cam to a different one.
t6378tp
07-05-2007, 04:11 PM
I'll give it a try but the only thing I forgot to add was that the truck was fine for about a year with the current setup and this is something that just started
67rsss
07-06-2007, 04:31 PM
Hesitation at transition is usually an enrichment issue. Make sure the floats are good before you do anything! Then, make sure the idle is set correctly, and that the throttle blade to transfer slot relationship is correct. Once that is done, adjust idle for good vacuum, and reasonable idle. You didn't mention much of the setup. While I don't know your carb in specific, there should be an accelerator pump function to help cover hesitation whenever there is an abrupt change in the airspeed over the discharge outlets. Sounds to me like you are not squirting enough extra fuel to cover for the reduced discharge signal at transition, but the symptom could be caused by other issues. If you are not comfortable pulling the carb and adjusting it, look about for a buddy that knows how, or at least a reliable shop. Tuning the carb isn't hard, but can get frustrating when you are still learning. You should have a manual that came with the carb that gives part numbers (reccomend buying a tuning kit), and usually also gives a good, step-by-step process for tuning that carb.
1997bird
07-06-2007, 07:47 PM
The Street Avenger carb's that I have gotten have always had the secondary float adjustment to high. Check that like 67rsss reccommended.
Cars4Kids
07-09-2007, 09:19 PM
Newbie Here...have the same carb on our 403 Nova SS...same problem...let me know if your adjustment works...and how accomplished...need to address my issue as well.
Thanks,
Steve
67rsss
07-12-2007, 03:58 PM
Both of you please read this...
http://www.holley.com/data/Products/Technical/199R10219-3.pdf
Shoudl answer your questions.
Hrod382
07-16-2007, 11:47 PM
This is too weird this comes up. Exact same thing is happening to me. Ran just fine then all of the sudden everytime no matter how hot when I lay into it from low rpm's it stumbles then comes back to life.
GOaT Cheese
07-17-2007, 12:51 AM
Your accelerator pump is out of adjustment.
t6378tp
07-18-2007, 10:40 PM
problem solved, turned out to be good old fashion dirt
thanks for the help guys
