JBsZ06
07-07-2007, 09:24 PM
2008 BMW M3
By GREG KABLE
AutoWeek | Published 07/06/07, 2:21 pm et
Photo Gallery:
>> PHOTO GALLERY >>
Gerhard Richter is reading our mind. How, we’re pondering as we prepare to drive it for the first time, can the new, fourth-generation BMW M3 get close to matching the qualities of the outgoing model? The outspoken head of development at BMW’s M division has lived and breathed this car for three years. He knows it better than anyone else—every last nuance, it would seem. He’s convinced it is a step forward.
“It’s different in a number of areas, but all the intrinsic M3 qualities remain,” he assures us as he walks over to the bright red coupe in which we’re sitting. He draws back on a cigarette and adds, “I don’t think you’ll be disappointed.”
With that, he whips the frameless door shut and guides us up the driveway of the Spanish resort in Marbella where BMW has chosen to launch its new M3, tapping his fingers on the expensive carbon-fiber roof that now comes as standard as a parting gesture. “Let’s talk later,” he says with a smile though the open driver-side window.
The map we’ve been given plots out a familiar route. Rising from sea level, it winds its way uphill over the Sierra Palmitera mountain range toward the ancient town of Ronda. It is as tough a test of a car’s dynamics as you’re likely to find on a public road. Peppered with long straights, fast and open sweepers set into rocky surroundings and all sorts of road surfaces, it is the perfect place to get to know the new M3. Later on, we’ll also get the opportunity to put the new BMW on a racetrack.
The new M3 is a bigger step away from the standard 3 Series coupe than any of its predecessors ever were. Right from the very beginning, it was conceived to be a more unique car than any time in its illustrious 20-year history. The new M3 and 3 Series coupe roll down the same production line at BMW’s Regensburg factory in Germany, but there’s now little that is shared between them. “It is 80 percent new in terms of its components,” says Richter.
The fourth-generation model boasts twice the cylinder count and double the power of the first-generation model. This speaks more about the competition than BMW’s desire to let the M3 slip into a power race. With the Audi RS4 and impressive new Mercedes-Benz C63 AMG in its sights, BMW has been forced to provide it with more firepower than the outgoing model. The question is: Has BMW gone too far? The key to the M3’s appeal has always been its responsiveness, the way its individual components all mesh together to provide fabulous tactility. Now it seems the engine is taking over the primary role. Or is it?
The new M3 was always going to get a V8. “We decided very early in the development process that the only way to move forward was to go with a bigger engine. The inline-six is still great, but it is at its limit from an engineering standpoint. There’s just no way we can wring any more out of it without reliability becoming a big issue,” reveals Richter. And what a phenomenal powerplant it is. Based on the same 90-degree architecture as the V10 found in the M5, it heralds in an exciting new era for BMW’s iconic performance coupe.
Significantly, the 4.0-liter is lighter and shorter than the six it replaces, allowing BMW to mount it farther back in the engine bay for an even more favorable weight distribution. It’s the output that steals the show, though. With a heady 420 hp at 8300 rpm, the new V8 endows the new M3 with 77 hp more than its predecessor while retaining the car’s reputation for delivering more than 100 hp per liter. Torque has also risen by 27 lb-ft to 295 lb-ft at a high 3900 rpm. Yet while the figures are impressive, it’s the deep baritone exhaust note that signals the biggest change in character.
This is one of the most-advanced engines ever to head into a road car: double Vanos variable camshaft control, individual throttle butterflies for each cylinder, equal-length stainless-steel exhaust system, force regulated oil supply and ionic current knock detection governed by the most powerful engine-management system BMW has developed—the so-called MS S60. A power button located down by the driver’s thigh on the center console also offers two different engine maps. Stick it in normal mode, and you think it feels strong until you dial up the more aggressive sport mode and there is a heightening in response. It is how we leave it all day. Topping it all off is BMW’s new brake energy regeneration system. It uses an alternator that is disconnected when the engine is under load, with energy flowing to the battery only under braking to keep efficiency high and power focus on acceleration.
If you’re getting the impression that just about everything about the new engine is dedicated to speed, you’re right. This car is fast. Gun it from a standing start with the ESP system deactivated ,and it will spin its rear wheels in first, second and—when you’re trying hard—third gear. BMW says it will hit 62 mph in 4.8 seconds, given the right surface—down 0.4 second on the old M3 but not quite in the same league as the new Mercedes-Benz C63 AMG, whose claimed 4.5 seconds makes it slightly faster up the strip. And the Audi RS4? Despite boasting four-wheel drive, it is claimed to take the same time.
Still, it is the M3’s in-gear performance that raises eyebrows when we find a deserted stretch of the snaking A-397 and let it rip. A fourth-gear 50-to-75-mph split of just 4.9 seconds is hair-raising in its intensity, shaming many mid-engined supercars in the process. This in a four-seat coupe weighing 3500 pounds. Blimey! Top speed is once again limited to 155 mph but with a high 3.846:1 final drive channeling the drive rearward, the new M3 is claimed to reach all the way up to 200 mph without electronic intervention. Charging hard on wide-open straights, its high-speed stability is impressive.
Then there’s the gearbox. BMW is not saying much at the moment, suggesting the six-speed manual fitted on all the cars at the M3 launch this week is suited to the new engine. It would, of course, and in combination with a new double-plate clutch, it proves to be slick in its actions. However, with plans for a new seven-speed double-clutch gearbox to make its appearance early next year, we’ll reserve judgment until then.
Slot back a couple of gears to send the new M3’s engine soaring. The immediacy is impressive for a production-car powerplant assembled to the same generous tolerances as the rest of the German carmaker’s engine lineup. Tapping the throttle sees it gain revs with rabid enthusiasm. Lift off, and it loses them with the same sort of focused zeal. They’re the kind of friction-free characteristics that BMW touts for its motorsport engines; an association it is keen to cultivate; the engine from the M3 and the BMW-Sauber Formula One car are cast alongside each other in the same light-metal foundry at Landshut in southern Germany. Production of the new M3’s V8 takes place alongside the M5’s V10 at BMW’s specialty-engine plant in Munich.
By GREG KABLE
Photo Gallery:
>> PHOTO GALLERY >>
