Small Block & Big Block Chevy Specific - Whats needed to use a 4l60e with a sbc or bbc?
Mr. Trick
07-14-2007, 12:26 PM
Here is the deal I'm doing a A4-M6 swap and my dad wants my A4. What does he need to put it behind a sbc or bbc. I remeber seeing a controll box or something like that made by jet performance on horse power tv a while back but dont remember exactly what it was called, but it was like a pcm for the trasmission. Also what kind of a converter is he gonna need I dont think he can use my ls1 converter.
Drumer919
07-15-2007, 12:35 AM
If he made it full manual valve bodies he wouldn't need a controller.
1989GTA
07-15-2007, 07:39 PM
TCI makes a contoller box and so does GM. I'm going to use the TCI controller when I swap to the 4L60E.
crazycamaro496
07-24-2007, 08:45 PM
I'm also thinking about doing this, is there a special bellhousing you need to use?
GOaT Cheese
07-24-2007, 08:59 PM
All you need to run a 4L60 behing a big block is a little drag net to go behind the car to catch the scraps, that way noone behind you will pop a tire on shards of steel and aluminum.
crazycamaro496
07-25-2007, 01:44 PM
yeah, i was considering the 4L80 if it's possible...anyone know if you can fit it up behind a big block?
Fbodynightmare
08-17-2007, 02:16 AM
Hey just a suggestion, would you document your swap .....money invested, work put in, pictures? :headbang:
