Stereo & Electronics - Gentex problem
Roadhouse
07-18-2007, 04:27 PM
I have a Gentex rearview with the temp/compass installed in my SS and a couple of days ago it started showing "OC" then it'll show a outside temp of (for example) -32 or 46 degrees or some off the wall reading. Anyone know what "OC" means? I'm thinking maybe the temp. probe died but I'm not sure.
LawmanSS
07-19-2007, 12:25 AM
Let's try this one in the Electronics section.
Roadhouse
07-19-2007, 07:37 AM
Okie doke, thanks. :cheers: So.. Anyone have one of these factory installed in another GM vehicle with maybe some info in the manual?
Roadhouse
07-19-2007, 11:32 PM
Anybody have any tips as to what might be the problem?
wabmorgan
07-20-2007, 01:18 AM
I'll check the manual for you...... I have one in my Silverado!!!!
wabmorgan
07-20-2007, 01:28 AM
Sorry..... no answer in the owner manual.
Suggest you refer question to the Preforamce Trucks section.... hopefully someone in there will know. (Just a guess.... but I would think it have would be something to due with calibration of the compass.) (There is a section in the manual on that... if you want I can post but it doesn't referance that error.)
wabmorgan
07-20-2007, 01:38 AM
Found this on another site(Thanks Google!!!!).... looks like it is a temperature senor issue..... your car probably doesn't have one!!! :(
(Please post back if you find a solution... I was thinking about this mod for my car.)
I just put in a gentex comp/temp mirror in my 2001 z71 and the temp display is showing OC. Can anyone help?
adalez71
View Public Profile
Send a private message to adalez71
Send email to adalez71
Find More Posts by adalez71
12-16-2003, 09:18 AM #2
adalez71
Posts: 14 Found the problem. Factory harness was there but the sensor wasn't.
WhiteBird00
07-20-2007, 08:43 AM
Try calling Gentex (616-772-1800) or their North American distributor Mito Corp. (800-433-6486) and see if they can tell you what it means and how to fix it.
Roadhouse
07-20-2007, 08:48 AM
I bought the mirror with temp sensor off ebay and installed it sometime ago (pretty easy upgrade BTW) and it has worked pretty good up until a week ago when the temp reading started showing "OC". It's got to mean something.
wabmorgan
07-21-2007, 12:21 AM
Maybe the temp sensor has went out!!???!????? Or has a loose connection????
Roadhouse
07-26-2007, 11:55 AM
I ordered another temp sensor and put it in. It seems to have fixed the problem, thanks all.
98mysticZ
07-26-2007, 08:59 PM
yea oc stands for open circut
