Stereo & Electronics - Question on components
2tone
08-16-2007, 09:42 PM
If you mount the crossover say in the rear of your car and your speakers are up in front. Would this affect the sound or anything? Or would it just be more wiring. Thanks.
95bat
08-17-2007, 12:13 AM
Nope, it'll be fine. Just have to run two sets of wires rather than one, tweeter and woofer will need different sets of wire.
fredmr39
08-17-2007, 01:01 AM
ideally, you do want as little wire as possible between the crossover and tweeter/woofer components
2tone
08-17-2007, 10:37 AM
Would it affect sound?
I have some Polk SR6500 and do not want the huge ass crossovers on my door panels.
95bat
08-17-2007, 07:26 PM
It won't hurt anything. Just make sure to run sufficient wire size, like 14 or 12 gauge, you'll be fine.
ipdking711
08-17-2007, 07:30 PM
either way a shorter wire is better. less chance of interference. think of it as a garden hose...after so many feet it isnt effiecient
dragonrage
08-18-2007, 10:04 AM
16 gauge is fine. I run 12 gauge because I got a 250' spool for cheap online, but it is by no means necessary.
2tone
08-21-2007, 12:19 AM
Thanks! :)
Dimitri-
08-21-2007, 12:38 AM
whoa crap.. didnt know that about the wires.. i sort of just coiled mine up in a twisty and left it in the door w/ my cadence component 6.5s... that was pretty long wire too
95bat
08-21-2007, 10:11 AM
Thats why I said to use sufficient wire size.
The wire has to travel that distance anyway, there is no difference whether it travels that distance up to the crossover mounted in the door or from the crossover in the rear to the speaker in the door. It's the exact same path.
ultraz
08-22-2007, 11:57 PM
you have to define sufficient Thickness. I know I ran 12 gauge all around..... i got it cheap by the spool too........ although my tweeters came with only 14-or 16 guage. it doesnt make a difference. Go as thick as the tweeter input.
As far as affecting sound, it wont affect it anymore than any other system without Time Correction. If your worried about delay, then youll need a nice deck with time correction, or amp, or signal processor.
dragonrage
08-23-2007, 09:30 AM
It's fine. Even at 16 gauge, you have to have a rather lengthy run of wire to notice a difference.
