Stereo & Electronics - Line Level ( RCA ) for factory cd player
Ryanmgaspard
08-18-2007, 07:53 AM
Where can I get the rca connections for an amp with factory cd player? Also, is it compatible with ipod adapter?
Snootch
08-18-2007, 08:39 AM
To connect an aftermarket amplifier to your factory deck, you are goning to need a Line Output Converter (LOC). Then, you will need to run the output wires to all the speakers. I dont believe there is an Auxillary input on the factory unit to support the output from an Ipod, but I could be wrong. I believe there are several threads that have been posted regarding this.
KEE AUDIO
08-18-2007, 12:33 PM
RCA connections for amps (line level converters) are outputs not inputs...if I understood your question. So no they won't work with an iPod. You can pick them up at Walmart if you wanted. Most autoparts places like Pepboys and Autozone have them as well.
