flenser
08-19-2007, 01:09 PM
Hello,
The front speakers in my '98 TA have gone bad, so I'm faced with a decision - simply replace them, or dig into the sound system and re-do everything.
Here's what I've done already. My stereo system is nearly stock, but I made one little change. The stock system seemed really weak in certain ranges. It had ok Bass considering the tiny factory woofers, but I was having a tough time hearing singers voices and other midrange instruments. So I replaced the small woofers by the back seats with full range speakers, using an amp wired to the full range signal that usually goes to the rear tweeters (according to the manual, the tweeters are the only speakers that get a full range signal), and the results were ok. I lost a little bass response but was able to tweak the amp output to fill in the missing midrange. I was planning on putting an 8 or 10" sub in the back somewhere, but I actually use the little side cutout space in the rear storage area for oversize items so I didn't want to fill it in with a sub enclosure. I also use the rear storage lid and occasionally remove it, so I didn't initially want to cut holes in it for subs even though I"ve heard this is one of the easiest ways to put in subs because it turns the entire rear storage area into the sounding box.
I am still using the stock stereo and it works just fine except the display is scrambled most of the time. It's been like that since I bought the car and it was replaced once while it was under the original warranty, but the replacement did the same thing and later on the dealer told me the stereos were so badly backordered that I might never get a good replacement.
I have one good quality 100w amp in the back, feeding the full range speakers next to the rear seats.
So... My choices:
1. Replace the front speakers with midrange speakers similiar to stock speakers.
2. Replace the front speakers with better full range speakers that have a built-in tweeter, ditching the mid plus tweeter config in the front doors.
3. Re-configure the whole speaker system using existing stereo, factory amp, andthe one add-on amp I already have.
4. Re-configure with new amp(s), new speakers, and maybe a new stereo.
I don't need super-loud bass and I don't listen to rap. I like rock and occasional classical music, so good full-range sound that can be tweaked to be heard over exhaust, wind, and road noise is what I'm looking for. I definately would like a little more bass but I don't want to spend hundreds of dollars just to get a little more bass response either.
Thanks in advance!
So... My choices:
Thanks in advance!
