Stereo & Electronics - replaced monsoon sails in TA, no sound?
onoiocoko
08-24-2007, 12:44 PM
i got some duel voice coil subs to replace the factory i was just told to connect the 2 channels to the 2 voice coils of the sub. i did this seperatly. i kept the factory plug and just spliced off the wires so i know i have positive and ground on right. i used the ED eu700s. i used this install guide http://www.ls1tech.com/forums/showthread.php?t=639901 i have a hole drilled for the port and a spacer made. mine isnt sealed yet, but im sure that the speaker just isnt even moving. even when i have the sub out of the sail pannel, i know that its not getting grounded out.
waltonscott
08-24-2007, 12:53 PM
why wouldn't your sub be grounded out? It's connected, right?
Are you sure you did your sub wiring correctly?
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Follow that to wire your subs correctly. I would get an amp to power those if I were you. That's my .02 :)
onoiocoko
08-24-2007, 01:26 PM
no i got 4 wires a side from the factory. im just trying to replace the factory subs. the write up says to just connect the 4 wires to the 4 sub terminals. they are the same ohms as the factory. but yea they are connected.
KEE AUDIO
08-24-2007, 02:03 PM
Just to make sure you have the right wires hooked up as far as polarity (pos./neg.):
Left side:
Tan +, White -
Dark blue with white +, Light green with black -
Right side:
Red +, Tan -
Dark green +, Light blue with black -
WhiteBird00
08-24-2007, 02:11 PM
You did get the correct 4+4 ohm double voice coil version of the eD subs, right? The 2+2 ohm DVC version won't work properly and could seriously damage your amp.
dragonrage
08-24-2007, 03:11 PM
Nah, damage wouldn't occur unless he cranked it hard. I assume he would tell us if they worked for a minute and then stopped working.
WhiteBird00
08-24-2007, 03:20 PM
Very true...just covering all bases.
onoiocoko
08-24-2007, 06:15 PM
umm im pretty sure i got the 4+4. i taped into the wires after the harness so there is 2 red and 2 black. should i tap straight into the wires b4 it?
waltonscott
08-24-2007, 10:19 PM
and only if his amp wasn't 2 ohms stable :)
WhiteBird00
08-26-2007, 04:20 PM
and only if his amp wasn't 2 ohms stable :)We're talking about the factory Monsoon amp. The sail panel subs in a Firebird are run off two 4-ohm channels each (that are not 2-ohm stable).
WhiteBird00
08-26-2007, 04:24 PM
umm im pretty sure i got the 4+4. i taped into the wires after the harness so there is 2 red and 2 black. should i tap straight into the wires b4 it?As long as you have a solid connection it doesn't matter if you tap in at the end or even all the way back at the amp - the signal is the same. There is the question of polarity but wiring them in reverse wouldn't cause the speakers to stop working.
onoiocoko
08-27-2007, 02:22 AM
well i did get one working on the side thats installed. the other side i just plugged in and it worked also. but once i drove around it stopped working. im thinkin that something keeps getting smashed in the install.
witHonor
08-27-2007, 07:57 PM
Are the wires getting pinched between the spacer and the metal?
onoiocoko
08-29-2007, 02:49 PM
i notched the spacer. i pulled it out again and got it working, playing with it. i dont know if the notch wasnt enough or what but its working now.
