Stereo & Electronics - Sail panel?
Simmons-Racing
09-27-2007, 07:27 AM
I have a 97 1LE and want to upgrade the speakers. How do I know if my sail panel speakers are subs or not?
Thanks,
Eric
WhiteBird00
09-27-2007, 08:05 AM
If you have a Monsoon system, they are subs. If you have the base audio system then they are "extended range" speakers (which doesn't mean anything except that they are full range speakers with high impedance).
The easiest way to tell if you have a Monsoon system is to see if you have speakers in the hatch area. Only the Monsoon had hatch speakers - the base system only had speakers in the doors and sail panels.
Simmons-Racing
09-27-2007, 06:11 PM
I have the window sticker from the car and it doesn't list "Monsoon" anywhere? I DO have the 4" speakers in the rear. I took the doors apart today to install my 6.5" Polk Audio db6501 speakers and found out someone had Blaupunk speakers already installed ? They were both cracking and sounded bad. The Polk's sound good, now I just have to figure out what to do with the sail speakers.
Eric
KEE AUDIO
09-27-2007, 06:48 PM
I have some sail panel replacements that would work with the Camaro. They start at $99.00 a pair for the CDT CL-E6 and go up from there. PM if your interested. I have these in stock and ready for delivery. Fit in the stock locations and just wire directly for the Camaro.
