Stereo & Electronics - Free-Air Subwoofers in the sail panels
has anyone one mounted free-air subwoofers in their sail panels .. i was thinking of going with 8" or 10" subs on each side ... amped up of course
or are regular subwoofers better
thanks
o yeah also
:pics:
Boodyrider
09-29-2007, 02:41 AM
Free air drivers REQUIRE a total seal between the face and the back of the driver, like mounting 'em on a big sheet of plywood.
You want bass, you NEED an enclosure. Sail panel is not gonna cut it.
KEE AUDIO
09-29-2007, 04:38 AM
I have CDT EF-8 8" subs in my sails and I actually regret it to an extent. Not that it doesn't sound good...it does, however, putting a good quality 6.75" midwoofer like a CDT M-6 or M-6+ would have been just as functional and sound just as good. In order to get a 8" sub in that location took cutting the sail panel metal and using a spacer for depth issues. Getting a 10" sub in that location would just be silly. I have 2 stealth enclosures I use with RE Audio SE10's. I have also used the CDT EF-100 sub in that location as a single 10" sub. The RE's have a deeper bass and the CDT's have much tighter bass. I'd go the traditional route with a stealth enclosure or a well enclosure for your subs and midwoofers in the sails. This coupled with aftermarket power would do well.
2MuchRiceMakesMeSick
09-30-2007, 05:51 AM
id rather have a much smaller speaker in the right airspace then a freeair. Just my opinion
