10 Second Club - Looking for low 11's or break 10's???
darkknight99
10-24-2007, 12:11 PM
1999 WS6
Stock bottom end
stock intake/TB
Absolute Speed stage 2.02,1.75 valves milled .010
Thunder chrome moly push rods
TSP 231/237 .598/.595 @112
Dynatech 1 7/8 Lt's
cutouts open
Slp 85 mm Mass air
30lb injectors
T-56(spec stage 3)
custom 4 inch aluminum D/S
12 bolt with 4:56's
running on prostars and slicks
100 or 150 shot if needed...
stock weight
Looking for 10's....can it happen...
98REDZ
10-24-2007, 02:51 PM
i'd sure as hell hope so
venom ws7
10-26-2007, 05:54 AM
Just get LS6 Intake 10s is not a problem at all with that setup if you can drive.
sleeperstyle
10-28-2007, 06:27 PM
yeah i agree on the n20. on motor probably not.
Do Work Son!
10-29-2007, 10:40 PM
Well shit, then does that mean my set up should be able to go 9's?
Weiand intake w 85 ml TB
x3 cam
match port and polished head and intake combo (stock ls1)
forged eagle stroker kit 3.905 bore 4 in stroke
jethot longtubes with 3 inch catback to cutout
wet 100shot
moser 12 with 4:10s
granatelli
centerforce stage 3
on stickies
98REDZ
10-30-2007, 03:12 PM
Yes, motor,...you probably cant expect 10's although a deep 11 shouldn't be out of the question if you drive the hell out of it. With the junk you better hit a 10
98REDZ
10-30-2007, 03:15 PM
x3 cam
wet 100shot
moser 12 with 4:10s
granatelli
centerforce stage 3
on stickies
Anything's possible, but im gonna have to say that the troubles from going from a 11 to a 10 are far easier than going from a 10 to a 9,....... So in other words,.....get your raceweight down to about 3,000lbs and give it a shot of 200, you should be there no problems then i would think as long as that head/intake combo is worth a crap.
