Small Block & Big Block Chevy Specific - big block questions
View Full Version : big block questions
sensi
11-28-2007, 02:21 PM
well Ive finally found a 95 camaro( no engine). I want to put a big block in, street driven, mostly track. Looking for out of the box performace(500+hp) Im totaly f-in clueless. where do I start? Where can I find more info on these transplants? tranny?
ulakovic22
11-28-2007, 02:36 PM
There is a sticky at the top you can read. Carb or fuel injection will determine how much cutting you have to do to the cowl. Get a BMR k-member specifically made for the swap and it will be tons easier. Your HP goals are they flywheel or rear wheel? Transmissions will be easy, LT1 T56 will bolt right up as well as any auto trans, LSx will take a little work.
sensi
11-28-2007, 02:41 PM
sorry man just saw the sticky(great info btw) any good engine distributors. hp to the wheels. carb motor. Power glide.
Street Lethal
11-28-2007, 03:29 PM
500/600-HP 427/454 Motown Small Blocks (http://www.worldcastings.com/index.htm)....
http://www.worldcastings.com/prods_pages/images/MotownDragRace.jpg
ulakovic22
11-28-2007, 03:54 PM
Powerglide is easy, just get the right crossmember. To the wheels isn't hard either, in the big bock shootout Paul Pfaff did a 9.5:1 454 that made 657 flywheel. That was using stock parts and a streetable hydraulic roller H/C set up. Only hard part will be cutting the cowk for your carb and then your fuel system since you'll be running a low pressure system.
sensi
12-03-2007, 11:26 AM
and what would be the advantage of compared to my lt1. besides the obvious ie. cubes, and ease of maintance
ulakovic22
12-03-2007, 12:03 PM
The ease at which you can make horsepower and torque. You can take a stock BBC and throw a H/C on it and make 600+ very easy. LT1 to get to 600+ would take A LOT and wouldn't be as driveable as a BBC.
sensi
12-03-2007, 12:24 PM
Very nice!! Im gonna give the guys a world castings a call. Any other good guys to keep in mind. That x-mas bonus is about to come in real handy.
JUICED96Z
12-03-2007, 01:54 PM
My 468 BBC from what I can tell is making 500+rwhp on the motor (raced a 350hp car when I was in second gear and he was in first and put an instant 5 cars on him). Keep in mind with with out of the box c port GM aluminum heads and out of the box holley strip dominator with a BG 850 carb that he ported to flow over a 1000CFM. Then you hit it with the two stages......
Once I have it gone threw and ported and have some things updated it will make 600 to the wheels on the motor.
Keep in mind this engine was built back in the 80's and cost next to nothing to build, just a lot of good parts matched together.
Car traped at 136 spraying a 150 shot out of second gear and will handle a lot more bottle.
Pump gas car but it likes 110 even on the motor, MPG is around 7-10.
BBC's drink more gas but they sound KILLER, the sound turns heads............
My cam is not huge either, big enough that I can't run power brakes but not big enough for a vac pump.
sensi
12-03-2007, 03:11 PM
cool any links to good engine builders. world products wanted a little more $ than Im ready to spend right now. Probley just have to go your route and grab parts here and there. Im not the best mechanic so I'd still like to find a complete engine somewhere if I can. Id like to have the car up and runnin by april. Any ideas
