Stereo & Electronics - How to run 4 gauge amp power wire
I'm hoping I can get some experienced tips on the best way to run my power wire from my battery to my trunk.
Thanks for the help!
Also any ideas on where to mount the amp would be helpful. I have a toolbox in my trunk and I would rather not leave the amp visible. It is unfortunately HUGE! Its a Cadence 750D
slow trap
01-27-2008, 01:42 PM
there is a rubber gromet on the passenger side firewall i ran mine through and just ran it down the passenger side under the carpet. just use a 4 way screwdriver and take out the kick panel and run it under the carpet and be sure to get it low enough so you don't run any of the screws through it.then on the back you probably won't even have to take anything loose to get it hid out of the way.i just had my 23-25" long amp setting in the bottom of the t-top well.
KEE AUDIO
01-27-2008, 02:38 PM
The grommet he is speaking of is actually behind the PCM (computer) so it won't be visible when looking for it. Most have to remove the PCM to access it. If your like the guy in the Burger King commercial with really tiny hands you may be able access it without removing it. lol!!
fredmr39
01-27-2008, 04:50 PM
http://shbox.com/fw/Firewall_wire_feed.html
KEE AUDIO
01-27-2008, 04:53 PM
Fred that is a great writeup! I saved that one in my favorites!! Good info!
zypher
01-27-2008, 10:01 PM
i think when i ran mine, i didnt even have to use the same grommet that the factory wiring ran through. if i remember correctly, we found an unused hole and ran the wire through it. but yea, it is pretty straight forward once you remove the CPU.
I ran it through there. It is the same place I ran my shift light. Oh baby Jesus, my stuff sounds good now!!
KEE AUDIO
01-28-2008, 01:54 PM
LOL!! Baby Jesus!
blackSSmoke01
01-28-2008, 08:06 PM
did mine the same way. no wires showing at all.
fredmr39
01-28-2008, 09:09 PM
If you're worried about screws hitting the wires, or running multiple wires, remove the seatbelt bolt and run wires on the other side of that.
Yes removing the seatbelt was a must
italicizedsponge
01-29-2008, 12:55 PM
I did it without removing the pcm and my hands arent that small. but im only 18 and im not big
KEE AUDIO
01-29-2008, 02:07 PM
An advantage when it come to installs!!
