10 Second Club - i want to go tens, damn it!
View Full Version : i want to go tens, damn it!
thndrracer
01-27-2008, 02:21 PM
i have a 2000 a4 ta with basic stuff/ported t/b/march ud pullys/slp cold air pack/ gutted cats/cut out/and a nx 150 shot. now that being said the car has done an 11.57@123 with a 1.9 60 ft.
this week i`m going to install my headers and lower control arms, and try for an 11.30 but i was thinking alittle gear will take it the rest of the way
what do you think? is it possible?
white mongoose
01-27-2008, 02:41 PM
what u need is a stall, with that and better gearing i think u should be the 10s, u really need to work on ur 60 ft drop it down to like 1.5 or something around there good luck
ncnumber8
01-27-2008, 11:06 PM
Your 60' is alittle high. Should be 1.5-1.6. Get that down and you'll probably be running 10's.
98REDZ
01-27-2008, 11:10 PM
Yeah its possible, although i'd say its even more possible that you blow that thing up before ya make it. Get a stall if you wanna make it happen.
BOLO
01-27-2008, 11:48 PM
White Mongoose is correct. High stall and a gear would get you there. And ofcourse TRACTION.
thndrracer
01-28-2008, 06:40 PM
how much gear are we saying? i was thinking 3400 stall/3.73`s
waterbug1999
01-28-2008, 06:42 PM
Yea, if you can get your 60' in the 1.5X, thats a 10 sec pass... Your 60' is what is killing you!
A 3500 stall with 3:73's will get it done. But, I like my 4K stall! :-)
Scoggin Dickey
01-28-2008, 06:48 PM
Spray off the line to cut a better 60ft. A good stall and spray off the line and you will be there :)
thndrracer
01-28-2008, 07:18 PM
i`m only using nitto`s for right now on stock rims think it will hold for a 1.6 60ft
waterbug1999
01-28-2008, 07:30 PM
I use a stock 16 + 8" rim and MT DR's and I can cut 1.4X's.
http://www.geocities.com/jody_abbott2000/BIR006.jpg
its turbo time
01-29-2008, 12:02 AM
nice times man, when i was full bolt-ons on the stock stall with a 100 shot my best was a 12.2, are you spraying out of the hole?
thndrracer
01-29-2008, 09:43 AM
nope still haven`t sprayed out of the hole and tom. i`m installing the headers and hoping to flush the trans
white mongoose
01-29-2008, 11:45 PM
yeah man a nice 4k stall some 373 gears and spray out off the whole and ull b in the 10s with no problem
suburbanlife866
01-30-2008, 07:10 AM
Yea well assuming his trans/rear end are stock....he can say goodbye to his wallet :devil:
BOLO
01-30-2008, 07:55 AM
"damn he wants 10's"
thndrracer
01-30-2008, 10:29 AM
yeah i know it not cheap and i`m not doing a 4000 stall, i`m hoping to get a built trans in the next month or so
its turbo time
01-30-2008, 11:12 AM
my short time was a 1.9 too, i guess those extra 50 ponies really make a difference. Or your car is just a freak...
bad6as
01-30-2008, 05:35 PM
what about a cam?
thndrracer
02-01-2008, 09:51 AM
my short time was a 1.9 too, i guess those extra 50 ponies really make a difference. Or your car is just a freak...i went 12.20 on the 100 kit and yes its a big diffrence between the 2,prob could have got better but i didn`t try and freak? nope the car went 13.9 at 100 when i got it now has a best of 12.8@109 na
what about a cam?
i`m thinking about a ms4 for now but i really want to build some thing bigger
its turbo time
02-03-2008, 04:39 PM
^when i said freak i meant like its a freak in the sense thats it has more power than most ls1's
thndrracer
02-03-2008, 05:15 PM
yeah i under stood but it`s nothing special by the way good looking car in your sig
5_02ls1
02-06-2008, 06:59 PM
must be 1 of those-da tracks...
thndrracer
02-06-2008, 07:49 PM
ALLMOTOR346CI
02-11-2008, 03:45 AM
Yea WTF???? is that supposed to mean....
its turbo time
02-11-2008, 11:23 AM
his sig hardly makes sense either^^
caMnaro
02-12-2008, 03:19 PM
-da as in the lower the da the better for times.So thats why your running so fast the track you race at has a low da
