Stereo & Electronics - Power Seat Hook Up
View Full Version : Power Seat Hook Up
TheMyth
01-29-2008, 02:52 AM
Does anyone know if a pair of power seats from an '02 T/A be hooked up in a '98 T/A without original power seats?? If so, how difficult?
Thanks.
CRAGER
01-29-2008, 07:49 AM
You should, they only have one way to wire our cars. I put T/A seats in my SS.
If you don't find a wire harness coiled up under the drivers seat, under the carpet then you'll just have to run a wire for it. Wouldn't be really that hard, fuse box is real close.
Peace,
Craig.
TheMyth
01-29-2008, 12:03 PM
Thanks, I will check for a harness when I get a chance. Right now the car is tucked away and hard to get at.
99FormulaM6
01-30-2008, 07:13 PM
the harness is there. I have power seats in my car, and it didnt come with them. The harness will be sticking out of the carpet towards the middle of the seat
WhiteBird00
01-30-2008, 09:44 PM
The cross-car harness for the lumbar support won't be in the car but it's easy to make. There are only four wires and you can just match them color-to-color to connect the driver's seat to the air pump assembly under the passenger's seat.
CRAGER
01-31-2008, 12:31 AM
But that wire harness is partnered with the two air tubes for the driver's seat from the air pump under the passenger's seat.
Peace,
Craig.
WhiteBird00
01-31-2008, 08:09 AM
Ordinary vacuum hoses can be used to replace the missing air hoses. I don't remember the diameter off hand but it's readily available in bulk from local parts stores.
99FormulaM6
01-31-2008, 09:39 AM
wait a second...a 98 TA shouldve came with leather and power driver seat.. all TA's did, didnt they?
CRAGER
01-31-2008, 10:59 AM
Yes, leather and power is standard. But lumbar was an option. If the seats have a pastic back with a net-pocket then it has lumbar.
Peace,
Craig.
TheMyth
02-03-2008, 01:07 PM
Apparently not, because mine is a '98 T/A with leather and the seats are not power. Also, contrary to a sticky I once read, my T/A is a GU2 car, meaning 2.73 gear.
CRAGER
02-03-2008, 02:54 PM
GU2 = 2.73 A4 car
If you're car is different, probably from previous owner.
Peace,
Craig.
