Stereo & Electronics - Interior light stays on
View Full Version : Interior light stays on
lickey7
01-30-2008, 02:36 PM
due to my drivers door switch, button or w/e it is, it makes my interior lights stay on, and my music still plays whenever i shut the car off...where is the button located...i wish it was on the body of the car where the door shuts so i could easily disconnect it but i cant find it..
Chattanooga
01-30-2008, 03:49 PM
bottom left of the door panel inside
should be to the left of the hood open
WhiteBird00
01-30-2008, 04:11 PM
No, 98+ f-bodies have the door switch mounted to the door latch assembly.
lickey7
01-30-2008, 07:01 PM
see thats what i was thinking because i couldnt find it...do you happen to know what color the wires r..i want to snip them because its getting really annoying driving at night with the lights on, and its hard to see
Chattanooga
01-30-2008, 09:21 PM
OHH
i had a 95 firebird and 95 camaro...
Now i got a 99 mustang... so much happier :)
WhiteBird00
01-30-2008, 09:41 PM
see thats what i was thinking because i couldnt find it...do you happen to know what color the wires r..i want to snip them because its getting really annoying driving at night with the lights on, and its hard to seeThey are grounding switches - the switch closes and completes the circuit to ground when the door is opened. The left door gets signal from the BCM on a gray with black wire, the right door gets the signal on a black with white wire, and both switches ground through black wires.
However, you might not want to bypass them because they affect other functions of the BCM besides the courtesy lights - alarm system and retained accessory power. The first thing to try is cleaning because road grime tends to make the switches stick. Also, there is a certain amount of adjustment in the switch play available by loosening the mounting screws. You might find that some adjustment will make the switches work properly.
lickey7
01-30-2008, 11:59 PM
ok so how do i have to get to it? take off the door panel im assuming
