Stereo & Electronics - Automatic headlights: How do you turn them off at night?
Dragaholic
07-14-2003, 02:35 PM
I know that there is a sensor somewhere (I believe in the dash somewhere) that automatically turns on the headlights when it reaches a certain darkness, I was wondering how you turn them off? Ive tried messing with the switch for the lights and no luck. The only thing that I can do is turn them on in the day. I want to be able to turn them off at night. Is this possible? If so, how. Thanks
hawgs
07-14-2003, 02:39 PM
Click the emergency brake up one click and it should cut the lights off…
Bowana
07-14-2003, 03:00 PM
I found this web page very helpful...
http://www.xse.com/leres/ss/drl.html
Scott
2000Z28M6
07-14-2003, 03:44 PM
There is another way with a switch. Go by LS1Camaro.net
Dragaholic
07-14-2003, 03:45 PM
I wasnt actually looking into disconnecting, modifying or taking anything apart, I was just looking for a way to bypass it. For instance, on the Chevrolet pick up trucks it has the automatic headlights too, but all you have to do is hit the dome override twice and they shut off. There has to be a way to do it on the Camaros too?
hawgs
07-14-2003, 03:56 PM
my reply must be invisible
megathumpzillaX
07-14-2003, 04:00 PM
too efficient
Toonz
07-14-2003, 04:56 PM
I pulled the fuse on my old GP to do this, have you looked into that?
Rob
Magyver
:D
ulySSes
07-14-2003, 05:07 PM
Dude, its not tough. Just do what hawgs said in his post above.
Dragaholic
07-14-2003, 07:17 PM
By clicking it up once, does it put any pressure on the parking/emergency brake? I know thats not the correct way to do it, is there a correct way? Didnt mean to ignore your reply Hawgs, but I was looking for a different answer, but I do appreciate your help. I just thought there was a way like the Chevy truck do. So wiring them up to the fog lights is possible? Anyone done them like that? How would I go about doing so? Is this a hazard? Thanks
hawgs
07-14-2003, 07:27 PM
its all good NVMySS :D
just putting it up one click doesnt put any pressure on the emergency brake. are you looking to drive around a lot at night without your lights on?
pulling the e-brake, is rumored to also disables ABS brakes. It could cause problems with ASR not working correctly as well.
Ryan.
PendragonZ
07-15-2003, 07:58 AM
Seems to be question for the electronics section to me.
SiggyBaby
07-15-2003, 09:45 AM
I would not suggest using the E-brake to disable your lights. As said above, it can cause wear on your system. Disable the sensor (I've been told it's mounted around the rear view mirror) or cover it up.
