Stereo & Electronics - Would two 1 farad caps be to much
Black96Z
03-03-2008, 04:01 AM
I curently have two alpine MRD-M500 amps in my car. They r 500 watts RMS and 900 watts peak each. Would two 1 farad caps be to much
porksoda
03-03-2008, 04:19 AM
Capacitors have been proven to be junk.
2MuchRiceMakesMeSick
03-03-2008, 07:08 AM
General rule of thumb is 1F for every 1000 watts
KEE AUDIO
03-03-2008, 07:21 AM
I wouldn't say a cap is junk unless it is poorly made. I would say that they are a bandaid for a substandard electrical system or an eletrical system that is not up to the demand placed on it. A better investment would be in a high output alternator and upgrading the stock ground and alternator power wire to larger gauge wire. A 160amp alternator runs about $145.00 for a brand new one. This would make your electrical system more efficient and negate the need for a capacitor.
Forklift
03-03-2008, 11:09 AM
like KEE said upgrade the under the hood wiring (big 3) and the alt, then a newer less restrictive style battery like a Kinetik or Stinger, then a cap or caps
Black96Z
03-07-2008, 12:52 AM
the thing is is that I have two caps sitting around that are new in the package
fredmr39
03-07-2008, 01:56 AM
Sell them....or one? Did you purchase them recently? Can't return them (or at least one)?
If not then of course - go ahead and wire up one for the heck of it...it's not like it will do bad things -- just isn't a cure for a new alternator (which I know you aren't doing). They do help smooth out the power flow slightly.
KEE AUDIO
03-07-2008, 06:39 AM
I agree with Fred. Won't harm anything so if your stuck with em might as well use them or one.
