Stereo & Electronics - Need a easy ground
Mikzgp
03-04-2008, 11:56 AM
I am trying to use my hard wire smart cord for my Escort 8500 x50. I have the wire ran down the pillar to under the dash. I found a power wire, but haven't found a good place to ground it. please help.....
WhiteBird00
03-04-2008, 12:00 PM
There is a factory ground stud under each side of the dash behind the kick panel trim.
pentavolvo
03-04-2008, 01:35 PM
anything metal
Z28LS1camaroguy
03-04-2008, 01:51 PM
why dont you just splice it into a ground wire, just find a black wire and splice it into it. good ground.
Mikzgp
03-04-2008, 02:01 PM
anything metal
I tried the metal support for the steering wheel with no luck. I will have to look for a black wire and just try to tap into in. The ground came with a loop on it and i was hoping for an easy way to use it and not cut the loop off.
pentavolvo
03-04-2008, 02:35 PM
the metal support for steering wheel should be legit im pretty sure my remote start is grounded there, u sure u have 12 volts on the other side
98boxer
03-05-2008, 12:41 AM
Thats what i did with my car stereo, but i keep reading that it should be grounded -other then black wire. Anyone know why?
ultraz
03-05-2008, 12:54 AM
careful, not every black wire is going to be a ground wire.
fredmr39
03-05-2008, 01:16 AM
Other than the harness ground? Setting your own directly to the chassis is generally better...though I have never had problems with the factory one provided for the stereo.
