D3xt3r
03-07-2008, 01:09 PM
Hey guys
I swapped a LS2 from a 05 GTO in my RX7 and have now completed the work. The problem is the engine just wont fire up. It will crank happily but I get no fuel and no spark. My wiring is done right I checked it many times and I get the switched constant 12V to the coils and the injectors its the pulsed signal that is totally lacking. I have Aeroforcetech OBD2 gauges hooked up to the OBD2 port and they show my all the engine stats. I get an RPM signal on cranking and it does some stuff with the fuel tables as I see it. The gauges also have a option to show DTCs but no faults show up.
Fuel Pump gets turned on an primered by the ECU and the fuel pressure is right at 58PSI.
Does anybody have an idea what it could be? I double checked on everything. Engine and is PCM are perfectly grounded. The switched and constant 12V sources are clean and all fused.
