Stereo & Electronics - Good sail subs?
View Full Version : Good sail subs?
NBM-LS1
03-08-2008, 09:14 PM
would KICKER CVT65-2 CVT work well with the stock monsoon amp? They are two ohms and that is what factor runs at. Lett me know your opinions.
rsodeputy61
03-08-2008, 09:24 PM
do a search....ton on it. only two i know of that work in the firebird are the elemental designs and kee audio now has an option with bazooka.
NBM-LS1
03-08-2008, 09:25 PM
I have been through them. I was checking because they run at 2ohms like the stock ones and they have a shallow mounting depth.
rsodeputy61
03-08-2008, 09:33 PM
u may want to double check...i think there's only those two options because they are 4 ohm. i think the camaro has the 2 ohm.
KEE AUDIO
03-09-2008, 04:20 AM
The Trans Am is not 2ohm. The Camaro is. If you try and run the SVC 2ohm you will blow your amp or do damage to it. The Firebird version is a dual voice coil 4ohms each voice coil which gives it a 2ohm load on the amp. If you run one pair of wires to the midbass then you need to have a 4ohm load because that is what each pair of wires impedance is. I carry several different drivers in a SVC 4ohm version as well.
