Conversions & Hybrids - New from Winnipeg Canada
JML55
03-21-2008, 10:17 PM
My name is Jean-Marc, my new project is to plant a LS engine out of a 2002 silverado into my 55 GMC truck. Here is a couple question, I have a 71 Firebird front clip on the truck, am'I going to run into clearance issues with the oil pan. I saw on ebay engine mount conversion kit to fit the SB cross member that move the engine back 1" and an other kit that doesn't, which one sould i used? Can a 700R4 fit the LS engine? Any tips welcome
Thanks, JM
SurlyJoe
03-22-2008, 10:49 AM
Hi Jean-Marc, nice looking truck you have there. I am in Brandon so nice to see another manitoba guy on here. Anyhow the problem you will have is the pan hanging down to low. It will depend how high you can have the motor sit in the truck body you might be able to get away with it. But if you use bought mount they will likely put the motor low enough that oil pan to ground clearance will be a problem.
A 700r4 will bolt up not sure how you would control the kickdown though.
JML55
03-22-2008, 12:23 PM
HI, i'm actualy in Fannystelle it's on number 2 hyw south of Elie. This is my first swap with fuel injection, i usualy stick to original resto. I have a 305 sb in it now and there is lots of clearance with ground, my consern was more with the crossmember.
JML55
08-20-2008, 10:42 PM
Here it is I finaly got the engine/tranny home, after a 6 month wait. (see attached pics) For 500$ I got a 5.3 vortec out of a wrecked 2002 Silverado with approximately 85000 kms on it. Came from a left over project at my work place. Was originaly 4X4 now has a 4l60E from a 2WD on it but I'm not sure what it came out off. Here is the tranny number, 4CHD104J, if someone can help ID this tranny please. Who ever pulled the engine out of the truck tried to save the wiring but didn't know what they were doing so I have a big mess to sort out. Nothing is marked and some of it has been cut. The plan is to try to get it running using the original wiring fist and then clean up what i don't need.
Jean-Marc
Carshopinc.com
08-21-2008, 10:41 AM
Your configuration should be easy to mount that engine in, The second gen f bodies have alot of clearance for the oil pan and you should be fine with a f body unit. I would use these plates first and see how it all fits
http://carshop.carshopinc.com/product_info.php/products_id/98457/C/S%202370
JML55
11-30-2008, 02:38 PM
Here is my first attempt at mounting the 5.3 in my 71 Firebird cliped 55 GMC truck. I will put the cab back on to see how clearance i have with the floor and firewall but for now i just wanted to see how it looks in the frame rail. My first concern it seems to sit very low. Oil pan is about 3 inches below crossmember. Exhaust are touching frame at the back and the heater outlet of the waterpump are very close to the upper control arm. Engine mount not done yet. Is there an other manifold i could use that would give me better clearence with the frame or do i have to go with headders.
TTLS1GP
11-30-2008, 06:45 PM
What pan are you using?
I have to wander over and see your progress.
JML55
11-30-2008, 07:09 PM
It has the truck oil pan .
TTLS1GP
11-30-2008, 07:41 PM
I have a set of LS2 manis that you can try and see if they will help you. They don't go down as far and exit in a different area of the log.
You may want to switch to the fbody oil pan to reduce the risk of pan damage.
JML55
11-30-2008, 08:02 PM
Thanks, Why don't you drop in next saturday we could check those manifold and share some ideas. First driveway south of town on 248.
TTLS1GP
11-30-2008, 08:08 PM
sure. I think i can see your house from here!!! hahaha
It will have to be in the afternoon as I need to be in brandon in the morning.
JML55
03-01-2009, 09:22 PM
Here my stand alone wiring harness been done. First id all connectors.
168505
Stripping all the tape and loom.
168506
168507
Removing unnecessary wires.
168508
168509
Extending the harness so the PCM will mount in the cab.
168514
168515
168516
Almost finish harness all i have left to do is to install DLC connector, MIL and power leeds from ign and bat.
168517
168518
V8Rumble
03-02-2009, 08:57 AM
NICE looking truck, :thumb: should be a great project! I'll be watching this one. :nod:
DarkRabbit
03-02-2009, 06:25 PM
Nice truck, look foward to seeing it this summer at some of the local shows and cruises
Spike-Z
03-02-2009, 08:04 PM
Love the body style! A pickup is my next project for sure.
NHRAMAN
03-02-2009, 08:07 PM
HI from Vancouver..gonna be a very cool truck man...:devil:
FeloniousMelon
03-02-2009, 09:18 PM
good luck from regina sask! gonna be ballin
JML55
01-30-2010, 08:50 PM
Well it has been a long time but here the latest.
http://www.youtube.com/watch?v=xRtZo-v0ces
Thanks to everyone that help me by answering some of my questions when i was putting my wiring harness together. After fixing some minor leak issues it fired right up. Looks like i did it right she run like a charm.
Stormed_Norm
01-31-2010, 10:34 PM
Very nice swap. Guess I'll be seeing you at some of the local cruises this summer.
JML55
01-31-2010, 10:39 PM
I sure will try, but i'm still looking for a hand to finish the body work. I'm trying to be done for the Super Run in Brandon.
TTLS1GP
02-02-2010, 10:27 PM
Wow! That's a good video. Who did that for you? :D
Now get some paint on that thing!
JML55
02-02-2010, 10:31 PM
Yes you're a funny guy.
Micah Johnstone
02-02-2010, 10:46 PM
Hey nice build and your a fellow Canadian,sweet.I am in Calgary and using a 5.3/4l60e into a 62 biscayne wagon.If you don't mind me asking what did you end up for fuses when you re-did the harness,i saw about 7-8 fuses,if you can remember what exactly did you fuse and with what rating of fuse,i have seen some conversions only using 4 fuses when done?I plan on doing my own as well and was just curious,did you get your info from lt1swap?
thanks and good luck
JML55
02-03-2010, 06:40 PM
This is what i done:
1. injectors 1-3-5-7 15 amp
2. drv coil 15 amp
3. injectors 2-4-6-8 15 amp
4. pass coil 15 amp
5. backup lights 20 amp
6. MAF 10 amp
7. o2's 15 amp
8. tranny 10 amp
9. PCM ign 10 amp
10. PCM bat 20 amp
I think that some can be attached together, but i like a more detail setup.
Jimbo1367
02-03-2010, 06:48 PM
Nice work. I wish I wasn't terrified of wiring/electircal stuff. LOL
Micah Johnstone
02-03-2010, 08:48 PM
Hey great thanks JML55,makes sense i tend to agree with what you did does'nt hurt to separate a little.
Thanks again
JML55
02-03-2010, 08:56 PM
Hey, lots of info here and on lt1swap don't be scare, its not that hard.
TTLS1GP
02-05-2010, 01:34 PM
I try!
When you bringing those links over for me to tig 'em?
