zacch123
04-11-2008, 06:13 PM
I am planning to do some upgrades to the speaker setup and have read through the forums on this but would like some feedback on what I plan to do. I am not interested in replacing the HU or the monsoon amp, but blew the passenger door speaker last week so figured a change was in order.
1) vert fronts are driven from the amp with 4 ohm tweeters 2 ohm mids. rear are driven from the amp with 4ohm/4ohm. I plan to install 4 ohm infinity 6002Is in both locations by snipping the speaker wires as has been documented. The tweeters will run off the 4 ohm feeds that are already in place. I know the monsoon amp has an LPF on the rear mid/sub connections so I intend to wire up the front and rear 4o hm infinity woofers in parallel on the amp's front speaker mid connections to create a 2 ohm load.
2) I have a sub box that sits up on the trunk ledge under the vert top I purchased from Johnny B awhile ago that will have two 8" subs. I plan to tap into the rear mid/sub connectors from the monsoon amp, run them to a new 2 channel amp using the speaker level input to drive the subs.
My questions are:
a) will I get decent midrange out of the parallel wiring of the front and rear infinity mids? I have seen mention about replacing the fronts with 4 ohm speakers and that the result is brassy or high vs the OEM speakers..will running the infinity speaker woofers in parallel making them a 2 ohm load help?
b) What kind of crossover point frequency is put out by the monsoon amp on the rear sub connections with the LPF? if I run this into a another amp (2 x 150rms to drive the 8" subs in the sub box, will I be feeding it a reasonable frequency range or since the monsoon only had to drive those small flat crappy subs in the rear does it not go down low in the frequency range?
thanks for the help in advance!
My questions are:
