Weezzer
08-02-2003, 11:40 AM
ok - Car is a 2002 T/A with 12,000 on the clock.
We were on the return leg of a trip and all of a sudden the headlights pop up/turn on, stay that way- then cycle on/off several times. Did that for about 75 miles then started acting ok- till we got to the house then it went nuts again. Each time it happens, I can hear a short comming from near the radio (from drivers position). Earlier this morning I heard the short a couple of times, and the radio lights seemed to flicker-but at that time the headlights were ok.
I seem to remember some threads on the "possessed" headlights, but I wasn't able to locate them with the search engine.
Any help you can shed on this, I appreciate. I'd rather fix it myself if possible -than to take it to the dealer.
-EDIT: I should also say I did add a shift light, but that was six months ago, I hooked the hot wire up to the switched wire running to the TCS control. I don't think this is causing any problem b/c the TCS is working fine along with the shift light. Nothing else is affected except the lights going bonkers by theirselves and the radio occasionally dimming/flickering when we hear the short.
update: Now they are turning on as soon as I turn the key to "run"- the lights turn on without turning on the headlight switch, they pop up and turn on as soon as I turn the key to "on". They go down when I turn the key to off-doesn't matter what the switch is set on.
