New LS1 Owners - Newbie Tech - Help new owner
mattyboy80
04-25-2008, 08:48 PM
Alright all. Just purchased an 02 WS6. Havin some problems with it already. Ill be driving and all of the sudden the tcs off light comes on the brake light comes on and the abs inop light comes on. When I shut the car off and restart it the lights go away. Anyone had any experience with this problem?
mattyboy80
04-26-2008, 10:11 AM
Anybody?
98FreakZ
04-26-2008, 01:50 PM
are you still running stock wheel and tire setup or have you switched?
mattyboy80
04-27-2008, 11:56 AM
Stock rims and the tires are toyo's. Everything else in the car is stock.
HDNVALLEY
04-27-2008, 07:44 PM
Check your brake fluid level first. Then check to see if you have a dirty or out of adjustment sensor at one of the wheels.
96gt4.6
04-27-2008, 08:05 PM
I also had that problem once, after I swapped my engine. The ground on the LF radiator support area was loose.
But those lights being on could mean other things as mentioned also. You really need to run the ABS codes, that's how I found my problem.
mattyboy80
04-29-2008, 04:21 PM
Figured out the Prob. The ECBM needed to be reprogrammed. So, If anyone has this problem that might just fix it. THe only horrible thing about it is it has to be done by a dealer for now. Damn dealerships :engarde:
