Chevrolet Camaro 1967-2002 - How do you change the oil pan on LT1
keycool1
05-29-2008, 05:39 PM
Do anybody know the easiest way to remove an LT1 oil pan while still on the car? any suggestions please!
EnfuegoZ28
05-30-2008, 04:05 PM
Unbolt the engine and jack it up a little. It's probably easier to pull the engine though.
keycool1
05-30-2008, 05:55 PM
Thanks for the info!
EnfuegoZ28
05-30-2008, 08:08 PM
No problem.
noriceinside
06-10-2008, 03:10 AM
dont pull the engine its not that bad.
use a hoist to hold the engine up, unbolt the motor mounts and lift the motor as high as you can. unbolt the cross member bolts but not all the way, leave them in a few threads. unbolt the pan and turn the crank until the all the crank throws clear the pan and it will slide out.
install is same as reverse. might as well change motor mounts while youre in there...
EnfuegoZ28
06-12-2008, 08:56 PM
There you go. Thanks for educating us.
