Small Block & Big Block Chevy Specific - Trying to ID SBC canted valve heads
Alexo35
07-12-2008, 08:25 PM
Just pulled te heads off my '89 Suburban. The motor was nothing special, but it had a pair of aluminum heads w/ canted valves. All they have is a serial number on the exhaust flange, no GM ID number. Any ideas how I an find out what these things are?
--Alex
99T/A
07-12-2008, 09:14 PM
I may be a little off on this because I have seen them in quite a while. In the late 90's there was a company called Canfield that I believe was well known for SBC canted valve heads. I will see if I can find anything and let you know.
Chris
99T/A
07-12-2008, 09:25 PM
I did a search for canted valve heads also known as SPLAYED valves. Apparently Brodix, CFE, GMPP, ect makes the splayed heads for SBC.Since we aren't sure what year the heads were put on there I would get a pic of the heads and start comparing them until you find something close and go from there.
xdamxincx
07-12-2008, 10:56 PM
ur probably getting them mixed up with some trickflow heads.. canted valve heads cost around 5 grand with all the hardware and need special pistons intake etc...get some pics up of them
mrdragster1970
07-12-2008, 11:48 PM
As said, I highly doubt anyone put a true canted valve on a suburban. Top dollar piece. Pic's needed.
Alexo35
07-13-2008, 02:31 PM
Here's the pics. No markings other than the serial number and the "X31203" stamp.
--Alex
xdamxincx
07-13-2008, 04:38 PM
trick flow twisted wedge
Alexo35
07-13-2008, 05:18 PM
Great. Thanks for the help. Any clue what they're worth?
--Alex
xdamxincx
07-13-2008, 05:44 PM
not really 500 maybe
