Small Block & Big Block Chevy Specific - Which cam to go with?
View Full Version : Which cam to go with?
F-Body Lover
07-13-2008, 12:13 AM
I found two cam's and cant decide which one to go with the engine will be 350 roller with vortec heads ported and dual springs for higher lift and edelbrock air gap performer rpm and stall converter and 3.73 its for 92 Z28 here are the cam's that I have in mind
http://store.summitracing.com/partdetail.asp?part=CCA%2D08%2D306%2D8&autoview=sku
http://store.summitracing.com/partdetail.asp?part=CCA%2D08%2D433%2D8&autoview=sku
I think I will go with the Xtreme energy cam
1997bird
07-13-2008, 03:18 AM
What size converter do you have?
ATCFLYBOY02
07-13-2008, 07:51 AM
I'd say w/ a 3500 stall the 1st one!!
F-Body Lover
07-13-2008, 10:34 AM
I will decide the size of the converter when I choose the cam
ATCFLYBOY02 why you choose the first one?
9000th01ss
07-13-2008, 12:45 PM
Static compression ratio is very important to know when choosing a cam. Whats your SCR and are you going by manufacturer specs or did you measure and calculate?
F-Body Lover
07-13-2008, 02:21 PM
I will put .030 flat top pistons I guess with 64cc it will be something aroubd 10-10.5cr
82 camaro
07-13-2008, 04:16 PM
With a zero deck height and a head gasket comp thickness of .039-.041 use the #2 cam from above you will need a good converter and gear to make this work.
9000th01ss
07-13-2008, 04:32 PM
It'll be more like 9.7:1
It won't be in the 10 range at all.
ATCFLYBOY02
07-13-2008, 06:29 PM
Well due to the RPM range w/ a 3500 stall you'll be into the lower part of the power band... Just the way I do things...
NightTrain66
07-20-2008, 09:03 AM
The bottom cam will actually make more low and mid range power and have a higher DCR than the first cam.
Make sure and get some good springs for either cam but especially the XE cam (145 lbs seat pressure 350 lbs open pressure).
lloyd
F-Body Lover
07-20-2008, 02:08 PM
Thank you guys I will just swap LT1 in my Z28
