Small Block & Big Block Chevy Specific - what pistons,heads, and cam will give a Compression Ratio: 9.4:1
sr_ryan1
07-19-2008, 06:06 PM
i have a 4 bolt main 5.7 casting number 3970010 engine and need a Compression Ratio of 9.4:1 to work with a mercruiser 350 mag MPI system.
this is going on a boat not a truck so i need to know what heads, piston, and cam to build this.
can anyone please help me?
sr_ryan1
07-19-2008, 08:18 PM
man the hell with that mpi system. im just gone go carbed
so what is a good head and cam pakage that makes power thoughout 1000-5000 rpm range?
mrdragster1970
07-19-2008, 08:25 PM
Call Brodix.
sr_ryan1
07-19-2008, 09:11 PM
the outdrive can only take 300 hp
mrdragster1970
07-19-2008, 09:43 PM
In that case, stock rebuild. Good luck.
92builtbird
07-22-2008, 12:01 AM
yeah, if it can only take up to 300 hp, my concern would not be bumping up the compression. compression= power. stick to about 9.1 or lesser.
78LT383
08-01-2008, 09:45 AM
do you have any heads now?
ATCFLYBOY02
08-01-2008, 01:06 PM
A stock mercurser is rated at NO MORE than 260hp. Seriously, I've been playing with boats just about my ENTIRE life.. If you have an ALPHA foot, go with a stock build. I've replaced over 10 of them on a Baja that I have at homebefore I upgraded to an Alpha 1, with a 260 hp Mercurser and a cam. Go with a stock build, being that you will most likely be turning 3-5K, I'd go with at least a steel crank (some came stock w/ one, make sure you check)
