Stereo & Electronics - installing sub question help and advice please
larryndog
08-10-2008, 10:20 PM
my firebird doesnt have monsoon and still has the stock headunit....i was planning on buying a 10" sub (rockford fosegate punch probably) a amp and a driver side stealth box...what else am i going to need? and this will work with the stock headunit?
thanks in advancee
KEE AUDIO
08-10-2008, 11:05 PM
You need an amp, amp install kit and a line level converter. I actually have all of the above including the enclosures and subs if you want a package put together.
larryndog
08-10-2008, 11:17 PM
you got a price?
No Juice
08-11-2008, 08:57 AM
To expand on this a little:
If I've got the amp install kit and line level converter, where is the best place to get the switch/signal from so the amp turns on and off with the radio?
I just installed my system in my 99 z28, use the RAP power wire - yellow wire in black connector. Works out perfectly. I also got the input for the converter from the back of the head unit. Thanks to whitebird00 for the info.
larryndog
08-11-2008, 11:41 AM
so i need an amp..amp install kit...and something like this http://www.electronixwarehouse.com/car/sgl-prod/accessories/line-converters/pyramid-ns60.htm
larryndog
08-11-2008, 11:42 AM
or do i need something like a rockford 3sixty
