Stereo & Electronics - After Releasing sidebrake head lights comes on
Engine_HP
09-25-2008, 06:17 AM
as the title says.
its a 1999 camaro after i realease the side brake the head light comes on this happens only when its dark.
how do i stop this from happining ?
thanks
jasonk
09-25-2008, 07:22 AM
there is a sensor for the automatic lights that must be tampered with, there are work arounds for it
edit: here is the link
http://www.ls1tech.com/forums/showpost.php?p=7096661&postcount=8
Engine_HP
09-25-2008, 07:30 AM
its too hard to get my hand under there and the upper dash pad breaks very quickly.
Engine_HP
09-25-2008, 08:58 AM
there are two connectors behind the stereo. what i did was... i disconnected on the them both the head light and the front yellow light went off. is there a way to disconnect only the head light and keep all the others working ?
WhiteBird00
09-25-2008, 09:08 AM
The same sensor wires that are shown being shorted in the other thread are in the plug you disconnected from the DRL module. You can use a Scotch Lock to short together the light green with black and yellow with black wires near that connector. That will make the system think it's daylight all the time and the headlights won't ever go on automatically (they'll still work normally with the switch).
Engine_HP
09-25-2008, 09:17 AM
that means i can eather have them all not working or have them all working.
cant i choose witch ones i dont want them to work ?
WhiteBird00
09-25-2008, 09:20 AM
I'm afraid I don't know what you're asking for. You originally wanted to disable the automatic headlights - that's what the instructions do. Now you want to disable the DRLs as well? With a switch?
Engine_HP
09-25-2008, 09:34 AM
ok.
i try to make my self clear this time.
what i want is after releasing the side brake i want my head light to go off but i want my park light (yellow light) to work and my dashboard light to work. without turning on the light switch.
WhiteBird00
09-25-2008, 09:40 AM
That's exactly what those instructions will do. The automatic headlights and the daytime running lights (amber front lights) are two different circuits - although they're both controlled by the same module behind the radio.
Shorting the two sensor wires together will prevent the headlights from coming on unless you manually turn them on using the headlight switch. But it won't affect the daytime running lights - they will still come on whenever the ignition is on and the parking brake is released.
Your dash lights won't come on unless you turn the headlights on. There is no mod to change that.
Engine_HP
09-25-2008, 09:44 AM
great those two wire are in the same connector i pulled out correct ?
are they in the blue connector or the black conector ?
WhiteBird00
09-25-2008, 12:01 PM
The two wires are side by side in the blue connector.
