Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > LS4 Front-Drives 2005-2009
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-31-2009, 05:07 PM   #1
Trader Rating: 0
Default I-shaft
I am getting some Intermediate shaft clunking.
I was wondering if I should get a genuine GM I-Shaft or go with an after market one if there is a good one, any suggestions welcome
92_Corvette is offline   Reply With Quote
Old 11-01-2009, 12:35 PM   #2
Count of Monte Carlo's Avatar
Trader Rating: 0
Send a message via AIM to Count of Monte Carlo
Save your money. If it is anything like mine, the shaft will still be tight but not greased up enough. Buy a tube of synthetic chassis grease and just pack it in as much as you can, make a mess if you have to, then clean up the excess. It will fix it good.
__________________
Lorenzo
'06 CHEVROLET Monte Carlo SS 53A4"Black Whale"
K&N Drop-In, Hooker AeroChambers Sans Resonator Gibson 3.5 Slashcut Tips, Sltted and Crsdrild Rtrs, Rotatd Torq Strut Mnt, F&R STB
'92 PONTIAC Grand Prix SE 34M5"Red Lobster"
Count of Monte Carlo is offline   Reply With Quote
Old 11-01-2009, 09:47 PM   #3
Trader Rating: 0
So did you just fill the boot with grease?
Old 11-01-2009, 10:10 PM   #4
2006 Chevrolet Monte Carlo
Mels SS's Avatar
Trader Rating: 0
Yes Count where did you put the grease?
__________________
http://i33.photobucket.com/albums/d94/BuffaloSS/Signatures%20and%20Avitars/Mels%20Sig/MelsSig2Custom.jpg
2006 Monte Carlo SS LS4
1996 Pontiac Grand Prix "The Real Show"
2008 Silverado Lt 5.3
2008 Silverado Lt 4.8
Mels SS is offline   Reply With Quote
Old 11-02-2009, 12:32 AM   #5
Trader Rating: 0
....I was hoping noone would ask me this...You'll see why as I explain it... The steering shaft has to be completely removed, which is not hard. Under the dash just pull back the boot and undo the nut. Do not confuse the nut end with the bolt head end, if you try to remove the bolt head you will just bust you knuckles. The jack up the nose of the car and remove the driver's side wheel. Look towards the steering rack till you see the white boot going up into the car. Raise the boot up off the rack and undo the bolt on that end. I think you can then pull the shaft out, either on the inside of the car or the outside...I dont remember... Once you get it out you will see the slip joint that has the splines....heres the erotic part.... as you try to move the joint up and down it should have a sticky action....That means its needs...lube.....Lube up splines on the shaft and try to get some grease on the back end opening of shaft by universal joint... work the lube in by moving the shaft up and down.... Really make a mess of it, just glob it on..... When you are done, just clean up the excess except what is on the is on the splines. Reinstall the shaft....
__________________
Lorenzo
Old 11-02-2009, 07:41 PM   #6
Trader Rating: 0
I just put grease in the boot itself and it seemed to fix it, idk if it worked it's way into the splines or what
Old 11-03-2009, 04:14 PM   #7
Trader Rating: 0
Quote:
Did you need a cigarette after finishing the job?
__________________
2006 Impala SS , Factory Navigation, !Mufflers, K&N Cold Air, Big Ass Tranny Cooler (11"x11" stacked plate)
2009 Saturn VUE XE AWD
1987 Buick Grand National
LS1 Racing is offline   Reply With Quote
Old 11-03-2009, 10:53 PM   #8
Trader Rating: 0
Well...Yeah! Like the one that Julie Haggerty smoked in AIRPLANE!
I really suggest pulling out the shaft and greasing it proper.
__________________
Lorenzo
Tags
2000, 2007, 2009, boot, buy, carlo, chevrolet, chevy, clear, grand, grease, impala, intermediate, ishaft, location, monte, prix, shaft, steering
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
