What are the differences between the LS4
Originally Posted by Mike's 01WS6
Crank is machined down on the ends and the accessory drive is more compact.
Originally Posted by Stampede4ever
So, the heads and cam are the same?
Thanks.
Thanks.
No... the cam is different. It is a dual-pattern (sorta)... DoD valves get a .492 lift... non-DoD valves get a .482 lift. It is more comparable to the cam in the LH6 truck engine which has .492 lift on all the valves.
Everything is listed here except the cams specs.
The LS1tech database was acting weird when I first posted... I couldn't tell if it actually made it in there... so I reposted it.
Originally Posted by MattSEG
Can it still mount to a t-56? Still has 6-bolt mains? Are the internals worth a damn?
Originally Posted by jfman
So we can mount these on a rear wheel drive vehicle ?
Only if you use a longitudinal tranny that has the same bolt pattern as Gm's front wheel drive transmissions. A tranny from a 3800 powered F-body should work. . . in theory .If your gonna do that then why not just get a LS1, LS2,LS6, LS7. Those motors are probably way more plentiful than a LS4. Just my .02 .
So a tranny from a 3.8 camaro will not bolt onto a ls1 motor ?
Originally Posted by Kazmaniac
To the best of my knowledge GM uses the 4L60E tranny in the F-Body. This trans is behind the V8 and the V6.
The 4T65e's used in the LS4 cars have a different case than the 4T65e's used in the v6 cars. GM used quite a bit of the LSx pieces with the LS4. It seems logical that if they went to the trouble of using a unique tranny case, they would keep LSx bolt pattern. But then again, GM does some odd things on occasion.
Chip
Chip
Originally Posted by evrae205
so doesn't that mean you could just swap the bell housings?
