Very interesting read over in this GTO forum...
http://www.ls1.com/forums/showthread.php?t=91206
"We have over a collective 100,000 miles and 6 months testing already. Checked the cylinders ( top end piston and walls) spark plugs etc. All cleaner than they were when we started....all reported ( including myself) smoother idles and acceleration and a increase in MPG."
"We now are over 130,000 miles on our test mules ( collectively) with no ill side effects. All positive. Dont forget this is really an old school "trick"...folks have been putting in Marvel Mystery Oil and 2 Stroke oil for decades.....what we did is fine tune it. Furthermore do not lose sight of the fact at a 500:1 ratio ( really 1oz to 5 gallons is more like 600:1) you have less 2 stroke oil than water/chemicals that came with your gasoline. So you cannot "hurt" or degrade anything....it is all good for long term.....The reason I call for the Marine 2 Stroke oil is it is designed for and the add packs are there for water cooled motors....lower combustion ratings and detergents we were looking for. Use it with confidence.
For you folks running E10....this is a must to off set the long term corrosives of the corn alcohol on your seals/gaskets/fuel rails......"
"the stuff in gas is everything from water to dirt/silicon/pipeline greases...what we do with the 2 stroke stuff is capture it and burn it in the combustion process versus letting it settle out in the fuel system....no negative impact on any sensors/cats/tuning.....the oil coats and protects your upper cylinder and rings....protects your fuel system...this is why some of our test mules put out lower emissions when tested than before...better compression from the ring packs getting cleaned.....more efficient means more MPG and more importantly more RWHP and longer component life. A great discovery about all this is we are getting lower wear metals from the cylinder walls being coated thus lower wear metals at start up....I just ran 500 miles and sent a sample in to the lab and got the report back today.......lowest wear metals EVER!
http://www.ls1.com/forums/showpost.p...6&postcount=78 "
